Can you clone a Skreem Module?
Old Oct 10, 2019 | 11:22 AM
  #61 (permalink)
phil alvirez's Avatar
Default Re: Can you clone a Skreem Module?
which brings us back to this:
Originally Posted by Viper-666
to 1) thank you
to 2) you are right, the Skreem can bring you and your xf in real trouble
to 3) today I don't have a real solution, I can repair a modul if the prozessor is OK
to 4) if you mean the shipping to britain or to germany you are right. The prozess of desolder the prozessor from the skreem, solder it to the adapte pcb, read out the prozessor, write the prozessor, desolder it from the adapter PCB and solder it back to the skreem is risky and costs a lot of time.
Also the skreem modul from usa and europe used different radio frequencies for the keyfob so i have to by spare parts in the USA. Therefore I can advise anyone not to send a working set (Skreem + PCM + keyfob) for modification.
If it is defective I can repair it or it remains defective so there is no risk for you and me that something will be destroyed.
I always work on a success basis, so if I can't repair it you only have to pay the shipping costs and customs.
For a repaired Skreem module I would take 200 USD and if someone supported the planned croudfunding campaign with a payment I would subtract this amount.
to 5) thats right
to 6) I wouldn't set a minimum, every dollar counts. But so I don't have to refund hundreds if we don't reach the target of $550, I would only refund amounts over $10. The remaining money I will then of course put into my further research.
so, what now? will be willing to send money?
guys?
Old Oct 10, 2019 | 07:44 PM
  #62 (permalink)
NH_Crossfire's Avatar
I have a question.
Last year, I ordered a Skeem, key, and antenna ring from Needwings.
My Mercedes guy said I needed the antenna ring but I ordered the entire setup. They replaced the antenna and the old key starts the car but the new key does not.
Does anyone have any ideas what the issue is? Should I put the new skeem in as well?
The old key is the only one I have and it's in bad shape.
Thanks for the help.
Old Oct 10, 2019 | 08:38 PM
  #63 (permalink)
Originally Posted by NH_Crossfire
I have a question.
I would say the car still has the old SKREEM in it.
Old Oct 11, 2019 | 03:00 AM
  #64 (permalink)
Viper-666's Avatar
I have a question.
The antenna ring isn't needed if the old one is not defectiv.
I don't know if the new Skreem from Needwings is a Clone of the old Skrem. In the Skreem are 8 keys programmed (the codes for the Transponder) key 1 and 2 is always used by the original keys.
I suppose, because nobody has managed to clone a transponder yet, that the transponders themselves still have a kind of serial number. And this number will be married with the Skreem when you use it for the first time.
That means if you have two transponders which have the correct code to unlock the immobiliser, they are unique because of the serial number and the transponder which is first used with the Skreem works, the other does not.
Would mean for you if the new key of Needwings is one with the code of key 1 or 2 and the workshop as suspected by onehundred80 has not installed the new Skreem module or has installed the new one and first used one of your old keys the new one can not work.
This is only a guess until now, because I can't create a transponder to verify this because I don't have the right hardware.
Old Oct 16, 2019 | 01:24 AM
  #65 (permalink)
what about this? https://www.crossfireforum.org/forum...ogether-3.html see post 49
Old Oct 16, 2019 | 02:03 AM
  #66 (permalink)
Viper-666's Avatar
The ECU shown there is different from ours.
With ours it is not necessary to desolder the EEPROM, it can be read and written on the board as mentioned above.
Old Oct 16, 2019 | 10:33 AM
  #67 (permalink)
g wheels's Avatar
Originally Posted by phil alvirez
Thanks phil for taking the time and making the effort to keep searching.
The video was a little hard to watch like most of youtube. I was amazed to see the use of a heat gun ON the chip. Never realized they could withstand the heat in order to melt the solder. I see he replaced the capacitors. Back in the 80s many failures were due to the dielectric drying out in them. Someone mentioned using a ZIF socket to easily remove and replace the eprom. I still suspect the solution could be to get around the skreem altogether by making the ecu think it has perpetually verified the security but I'm way out of my league. Sometimes the answer starts out of the mouth of babes..
I have a lost co-worker that took at least one of his crossfires out of state and had the security removed. I'm going to try and locate him to ask just what it took to do that. Hope it isn't a dead end..
Old Oct 16, 2019 | 10:41 AM
  #68 (permalink)
" I have a lost co-worker that took at least one of his crossfires out of state and had the security removed. I'm going to try and locate him to ask just what it took to do that. Hope it isn't a dead end.."
terrific news.
we all wish you succeed reaching him and getting the details...
that would be the best way.
Old Oct 16, 2019 | 12:56 PM
  #69 (permalink)
Viper-666's Avatar
That were amazing!
Old Oct 17, 2019 | 02:05 PM
  #70 (permalink)
g wheels's Avatar
That were amazing!
I realize it sounds like more bullshit and I should have deferred to post until I had something believable but I have located the person who currently owns an 05 SRT6 that has eliminated the security. The folk involved have been reliable people in the past so I am anxious and hopeful for myself and everyone else to have a viable solution. If it turns out to be a loser I'll own up to it..
Old Oct 17, 2019 | 02:59 PM
  #71 (permalink)
now, to add to the confusion, there are these available: https://www.ebay.ca/itm/223576786595
where did they get them?
what has to be done to have them functioning?
Old Oct 17, 2019 | 03:55 PM
  #72 (permalink)
manlaw38's Avatar
Talking Re: Can you clone a Skreem Module?
THIS IS GREAT NEWS ,
I hope this means that any cut key will start our cars if this works it will fix this horrible problem we all do and possibly suffer from a potential skreem failure. I wish we could gut the skreem and throw them all away .
Old Oct 17, 2019 | 04:36 PM
  #73 (permalink)
g wheels's Avatar
Unhappy Re: Can you clone a Skreem Module?
And now is where I've learned something. The friend to which I spoke just called me and I got the story. He's a member here on CrossfireForum.org. The story got to me 3rd hand and what he had done was a tune that removed the speed governor. I suppose it is a fuel cutoff when the vehicle exceeds the tire speed rating. Not even close to a security system bypass. I'm truly sorry and ashamed. I'll be more careful if there is a future..
Old Oct 17, 2019 | 04:50 PM
  #74 (permalink)
back to this:
these are available: https://www.ebay.ca/itm/223576786595
and they dont look the same as the originals:
Old Oct 17, 2019 | 05:49 PM
  #75 (permalink)
manlaw38's Avatar
Wink Re: Can you clone a Skreem Module?
Its ok !! I am not mean like others can be on this forum you tried your best and so be it !! At least you tried !!
Old Oct 18, 2019 | 02:19 AM
  #76 (permalink)
Viper-666's Avatar
back to this:
I don't think you can get it to work, because you need the codes for the ECU see above, the yellow marked section of my ECU dump. In the DBR3 tool it gives a routine to learn a virgin Skreem modul to the Crossfire but I can't get it to work. So maybee it can work with the right DBR3 tool StarScan??? Witech MicroPod2 dosn't make the job in my test. But maybee you need also attech to the Mopar Tech Authorithy and this isn't offered for private persons.
Old Oct 18, 2019 | 03:00 AM
  #77 (permalink)
sadly, we find ourselves in a place where technology rules, and any1 can sell anything without guaranteeing that it will work as you need-and we dont understand whats going on.
look at their ad:
Genuine Mopar OEM NEW Ignition Lock Set Assembly 2004-2008 Crossfire 5101014AA
New OEM Factory Part
sure any1 will buy it thinking (dreaming/expecting) that it will work, but the ad does not confirm that you will have your car running with it.
i, like zillions, am ignorant of all these facts, and am at the hands of those who sell them. no law to protect us, the little guys.
i remember an anecdote of a poor farmer that saw his chicken being taken by a group of revolutionaries and when he was protesting, 1 of them told him that it was for the good cause.
but other revolutionaries were doing the same. and then he added: my chicken dont know who steals them. they only know that they are being stolen
so all this chrysler/benz/mopar/whatever ends up leaving us at their mercy-as always.
the only thing that seems feasible is getting rid of the skreem.
Old Oct 18, 2019 | 01:06 PM
  #78 (permalink)
Toolman's Avatar
look at their ad:
Phil, it appears you have missed some related message threads on this. I certainly understand your skepticism, but I have a little more information than you on it. I purchased this kit, and so have others on the forum. It is a genuine Chrysler part number/kit. The seller has sold 7 on the current ebay listing, and 10 on a prior listing, with no related negative feedback. There is certainly debate on the forum as to whether or not they will work. I happen to have the Chrysler documentation for installing a virgin SKREEM, and both a DRBIII, and Starscan that have program functions to replace and configure a SKREEM. The documentation can be wrong, but why would Chrysler provision this kit? I've never personally done this, and I will acknowledge it could fail. However, I'm confident it will work if I need it one day for one of my three Crossfires. I'm not willing to waste a $500 kit just to prove it. However, I have volunteered in another post to help others locally who are stuck. Or I would do the replacement on one of my own cars, if others would split the cost of the SKREEM kit. One individual has shown some willingness to do that, but I warned his request to do an ECU change at the same time would complicate things and invalidate the test.
The SKREEM comes paired to the two keys "chips" in the kit so it is already set up to talk with them. The labels on these parts all have a matching code. The replacement process involves pairing the virgin SKREEM to the existing ECU. I forget without looking at the documentation but you to read Hex codes from the ECU using the DRBIII, and then going through the DRBIII prompted steps where at some point you have to enter the ECU codes. I started that module replacement function in the DRBIII and it first asked me to select a country. As I didn't want to mess up the good SKREEM in the car I stopped at that point.
BTW, related to your post, those performance boosters "chips" you plug into your car ODBII port are all scams. There are youtube videos where very good technical evaluations have been done proving so.
Old Oct 18, 2019 | 01:27 PM
  #79 (permalink)
Originally Posted by Toolman
Phil, it appears you have missed some related message threads on this. I certainly understand your skepticism, but I have a little more information than you on it. I purchased this kit, and so have others on the forum. It is a genuine Chrysler part number/kit. The seller has sold 7 on the current ebay listing, and 10 on a prior listing, with no related negative feedback. There is certainly debate on the forum as to whether or not they will work. I happen to have the Chrysler documentation for installing a virgin SKREEM, and both a DRBIII, and Starscan that have program functions to replace and configure a SKREEM. The documentation can be wrong. I've never personally done this, and I will acknowledge it could fail. However, I'm confident it will work if I need it one day for one of my three Crossfires. I'm not willing to waste a $500 kit just to prove it. However, I have volunteered in another post to help others locally who are stuck. Or I would do the replacement on one of my own cars, if others would split the cost of the SKREEM kit. One individual has shown some willingness to do that, but I warned his request to do an ECU change at the same time would complicate things and invalidate the test.
BTW, related to your post, those performance boosters you plug into your car ODBII port are all scams. There are youtube videos where very good technical evaluations have been done proving so.
thank you very much for your polite comments and suggestions. still, the more information you have does not prove that those parts work. it will not be until you (or somebody else) tells us that have been installed and do work as expected.
and about the performance boosters you mention (in which post? number? link?), i dont understand what are you talking about, so please elaborate. thanks again for your comments.
Old Oct 18, 2019 | 02:09 PM
  #80 (permalink)
Toolman's Avatar
Here is a youtube link that shows you what they are and testing with real a dynamometer.
