Boost issue
Old Jun 17, 2019 | 11:20 PM
blackpepper's Avatar
Default Boost issue
Has any ever experienced a pulley going bad I have a 62 and the back plate is very shiny and not make the 19 to 20 it normally does ,I leaktest the car switched back to stock manis still only making about stock boost I tested the magnet at well I ran power to it and couldn't turn it I removed my pulley shims gap was
040 now it's about 020 with shim I replaced supercharger belts bolt belts pull the same boost about 14psi also I have been running DJs belt wrap kit for year no issues til this last 3 weeks
Old Jun 26, 2019 | 09:59 PM
Default Re: Boost issue
Anyone else that can't get a answer up here check your pulley gap had to end up replacing my 62mm with a 61mm
Old Jun 27, 2019 | 09:51 AM
These after market pulleys are not made with decent springs, some are made with non spring material. When the gap decreases after being deflected just .040 initially then it is not a spring. The wrong material being used causes the springs to break and damage parts in the surrounding area unless the guard is used.
Gull wing
Oct 7, 2016 04:15 AM
X-Feuer
Jun 30, 2012 03:47 PM
jumpoutchuck
Dec 29, 2006 04:33 PM
petez Racing
May 16, 2006 06:51 PM
CyberGreg
Jan 4, 2005 04:36 PM
