Radio and anti tow module
Old Sep 15, 2019 | 07:44 PM
DualSportDad's Avatar
Default Re: Radio and anti tow module
It would be helpful if you told us when this happened, did it just come out of the blue or did you do something.
I have never heard of this issue on the Crossfire. If the radio had been changed or messed with in some manner the constant on power may have been switched in place of the switched power.
The OEM radio can be turned ON with the ignition OFF. It will switch OFF after a set time or when it senses the battery is getting too weak.
Case NumberK21807142
Vehicle IssueRadio will turn on with out the key in the ignition.;Base or navigation radio.
System or ComponentAbnormal Behavior / Function;Customer Concern (No DTCs);Radio;Ignition Turned Off
RecommendationIt is normal for the Crossfire radio to play without the key in the ignition.
Modification Date02/27/08 3:18 PM
correct but i think if i recall you can turn it back off and it will start to behave normally again. i remember coming across this exact issue once but i can't remember if i ever found a issue.
Old Sep 15, 2019 | 08:24 PM
BrianP's Avatar
as far as the radio-it still comes on for no reason.
I was just working on the door lock issue, pulled a relay, replaced it, cycled the lock unlock on the key fob, and the radio started playing.
As for the pump, i here a click when going from lock to unlock-but no other noise.
Hard to believe that the pump died just as i was working on other issues.
Brian
Old Sep 15, 2019 | 09:17 PM
Is there ANY chance someone in the past put a stupid 'remote start' kit in this car? Or perhaps ANY aftermarket security or sound system?
Old Sep 15, 2019 | 09:51 PM
BrianP's Avatar
Nope, Have owned this car 7 or 8 years now. No remote start,no aftermarket alarm, stock sound system.
I can live with the radio issue, it seems if you manually turn it off before turning the car off, it stays off.
Now if i could get the door locks to function again!
bhindzioncurtain
May 28, 2017 10:13 AM
zalsaigh
May 2, 2013 11:09 PM
turbomar
Dec 3, 2011 02:53 PM
jim dyrdahl
Nov 9, 2008 04:35 PM
Louie K
Aug 11, 2007 08:25 AM
