Electrical Problem - Please Help
Old Mar 11, 2020 | 03:49 PM
mejiandy's Avatar
Default Electrical Problem - Please Help
Today as i was driving my rear spoiler button started flashing and the spoiler opened by itself. Then the BAS/ESP, ABS and Airbag light is came on. Then My car went on a limp mode so i pulled to the side of the road and switch off the engine and then it didn't want to start again, the windows stopped rolling up but they will rolled down. After a few minutes the car started to recuperate the electronics but it wouldn't pass to ignition, i would hear or listen to the started but no crank. The car was towed home on a flat bed and when i parked i rolled it down the ramp and turned it on by clutch, the car turned on for a few moments, but worked on a safe mode as it was gasping for air and the throttle (gas pedal) wouldn't work and the motor vibrated as if some spark plus were down.
Any ideas or assistance or a where to start would be greatly appreciated.
Old Mar 11, 2020 | 06:52 PM
bluecoupe's Avatar
Default Re: Electrical Problem - Please Help
Reading trouble codes is a good place to start.
Old Mar 11, 2020 | 08:45 PM
First step: Have the battery load tested.
Old Mar 12, 2020 | 12:23 PM
mejiandy's Avatar
Gentlemen thank you for the reply, no error codes or engine light on, i jump start the vehicle and did a load test while on and it was reading only 11amps while on, removed the alternator took it to Advanced Auto parts, they tested it and said it was bad, got the new one and will install it tonight. Will come back to post the conclusion.
Old Mar 12, 2020 | 12:46 PM
Johnny Versatile's Avatar
I wouldn't jump the car to start it. These things have really fussy electrical systems. Put a charge in the battery. Looks like you are on the right track.
Old Apr 7, 2020 | 11:43 PM
Space coupe's Avatar
What were you're results ?
Old Apr 8, 2020 | 12:18 AM
Obviously not a man of his word, NOT.
'Will come back to post the conclusion.'
Crossfire725
Jan 16, 2013 11:32 AM
Cal_Cobra
Sep 24, 2012 08:34 PM
Lee Jones Jnr
Jan 3, 2010 07:49 AM
special_kxoxo
Dec 27, 2009 07:27 PM
caughtNthexfire06
Apr 29, 2009 05:52 PM
