grommets for breather cover
Old Apr 27, 2020 | 01:30 PM
droopaloop's Avatar
Default grommets for breather cover
Anyone know where to get bolt grommets for the breathers that are on top of the valve covers? or is it a case of using gasket maker?
Old Apr 27, 2020 | 03:48 PM
Default Re: grommets for breather cover
The gasket maker goes around the screws as well. Use new screws as well, stainless steel or aluminum screws.
The aluminum screws are one time use only.
Old Apr 27, 2020 | 05:29 PM
droopaloop's Avatar
ok, Thanks!
Old Apr 27, 2020 | 07:07 PM
ok, Thanks!
Regardless of what gasket material you use, make SURE you follow the torque requirements of the bolts you are tightening!
dylan07
Aug 20, 2017 09:19 PM
ardenian
Oct 23, 2015 09:05 AM
csteve0355
Jul 4, 2013 01:40 PM
LugNut
Apr 19, 2013 08:57 PM
Buckwheat
Feb 11, 2010 03:28 PM
