Sticky key fix now no ignition
Old Nov 2, 2020 | 12:39 PM
meh03's Avatar
Default Sticky key fix now no ignition
I did the sticky key fix yesterday and now the key turns fine but the car will not start. Will not crank, no ignition. I replaced the car battery that was shot since it has been sitting for a while. The rest of the electronics work fine. I failed to look at where the key ring was before removing it (around the key hole that communicates with the FOB) but I reinstalled it with the wire at the bottom as a youtube video said. I will pick up a new battery for the FOB just in case.
Any ideas? Any help is greatly appreciated.
Thanks
Old Nov 2, 2020 | 01:22 PM
meh03's Avatar
Default Re: Sticky key fix now no ignition
I did some forum searching. Sounds like it might be the RCM. I'll pull it tonight and take a look.
Old Nov 2, 2020 | 02:44 PM
Was it starting right before the sticky key fix?
Old Nov 2, 2020 | 02:55 PM
meh03's Avatar
It was if I kept trying several times and was getting worse and worse. I thought that also had to do with the sticky key problem. No?
Old Nov 2, 2020 | 04:52 PM
You are correct, sounds like your RCM. You can send it to DJ Tighe for rebuild. Do a search of RCM on this site.
Old Nov 2, 2020 | 05:24 PM
meh03's Avatar
Thanks. I ordered a new one. Once I swap it out, if that's the problem, I'll send the old one to him for repair and throw that in the glove box as a spare next to the spare CPS sensor. Gotta love the electrical on these cars
Old Nov 2, 2020 | 05:31 PM
KDW4Him's Avatar
Battery for the FOB only has to do with remote lock/unlock function.
The most common issue for no start after sticky key work is ring not replaced around key hole or ring wire came unplugged from SKREEM.
Old Nov 2, 2020 | 05:34 PM
KDW4Him's Avatar
Start/crank issues are not a sticky key issue symptom. Specifically if the car would crank and not start it's the CPS. If it wouldn't crank at all it's the RCM.
Old Nov 2, 2020 | 08:55 PM
We had a private conversation, I think we got to the bottom of this and he's on the right track, everyone.
Old Nov 2, 2020 | 10:35 PM
meh03's Avatar
Yep. Thanks everyone. I’ll update once I get the new RCM and hopefully close this one out.
Old Nov 9, 2020 | 02:50 PM
meh03's Avatar
Replacing the RCM fixed it. Fired right up. Thanks to all!
Old Nov 9, 2020 | 03:17 PM
Thanks for the follow up, so many do not.
Old Nov 10, 2020 | 12:58 PM
I was extremely lucky. When the RCM went bad in my 2007, the car was sitting in my driveway. Like you, I bought a new RCM from RockAuto & sent the old one to Tighe for repair. Now I have a spare RCM.
treyleblanc
Sep 17, 2024 06:26 PM
barrysmith
Jan 8, 2019 04:53 PM
fastfred
Nov 5, 2018 09:47 AM
tracyclifton
Oct 18, 2016 04:15 PM
Dennis B
May 30, 2014 07:02 AM
