Intermittent Start Failure
Old Nov 29, 2020 | 12:24 PM
davezipter's Avatar
Default Intermittent Start Failure
Hopefully someone can help... intermittently my 2005 SRT 6 convertible will not start. On turning the key, the engine cranks normally but makes a “chuffing” sound from under the hood. Believe it or not, I can get the car to start by telescoping the steering wheel three or four times and then turning the key. Any ideas?
Old Nov 29, 2020 | 12:45 PM
UrbanE's Avatar
Default Re: Intermittent Start Failure
Have you attempted to self diagnose or attempt to narrow down the cause
Any suggestions pop up when you entered the issue into the search bar? Help us so that we can try to help you
Old Nov 29, 2020 | 03:36 PM
KDW4Him's Avatar
Crank but no start is usually the Crank Position sensor. Good power on but no crank is usually the Relay Control Module solder connections.
tropixcale
Jul 19, 2016 03:42 PM
gronda
20
Jul 29, 2015 03:07 PM
orefin
Jun 28, 2014 11:15 AM
Smokin Red '06
May 24, 2012 05:46 PM
ri2300
Nov 22, 2010 05:48 AM
