Skreem module failure
Old May 25, 2021 | 05:39 PM
Gregg777's Avatar
Default Skreem module failure
2005 Roadster with dealer diagnosed Skreem failure.
Know anyone that repairs these and then can reprogram.
Chrysler and Mercedes no longer support this car
Old May 25, 2021 | 05:52 PM
Default Re: Skreem module failure
Not a Roadster-specific topic, moved to tech forum.
Old May 25, 2021 | 05:56 PM
There are countless threads in the tech forums on this. Your best best is Needswings.com, or SOS DIagnostics or Josh Chase's Mercedes Swap Shop.
And an email address is not a location, change that to your town and state and others will know where you are.
Old May 25, 2021 | 05:59 PM
Also many times it is the RCM and mistaken for a screem issue.
Old May 25, 2021 | 06:10 PM
You do not have to believe what the dealer said, lying is considered a part of customer relations.
He may be correct though, what are your symptoms?
If it is the SKREEM it can be fixed though, have faith.
Old May 25, 2021 | 07:20 PM
These guys are right. I missed what I put in bold above.
You probably just have a bad battery, or a blown fuse #11 (hell, most dealers would diagnose low tire pressure as "bad springs and shocks"....)
See my sigline.
Then why not tell us what, exactly, the car is doing? If you live near Zachary Joslyn, Josh Chase, Chuk, Rick Dunmeyer, etc., they will probably have the car running same day.
Old Jun 7, 2021 | 12:27 PM
CaughtInaXF's Avatar
Of course....
Old Jun 7, 2021 | 01:33 PM
OP has not replied once in two weeks so we might as well forget this thread.
Old Jun 8, 2021 | 09:17 AM
Gregg777's Avatar
Sent "dummy box" and found out it was an empty lot.
need CONFIRMED reliable resource of plug N play.
No BS .
Can you do the job?
Old Jun 9, 2021 | 09:51 PM
Gregg777's Avatar
Gregg777 is located in Orlando,FLLOCAL SKREEM SUCCESS HERE??
Old Jun 9, 2021 | 10:47 PM
Amazing, no symptoms described so maybe it is not the SKREEM at all.
Sends empty box somewhere.
Asks for reliable source for repair although they have been mentioned.
This could go on forever, l give up.
razz19
Sep 10, 2024 10:22 AM
mommanutts
Jul 30, 2019 10:57 AM
