Skreemulator the Skreem replacement
Old Jan 18, 2023 | 01:06 PM
Viper-666's Avatar
Default Skreemulator the Skreem replacement
Hello,
after 4 years of development and almost 2 years of testing I am proud to have the final version of my Skreemulator ready. At this point I would like to thank the beta testers who trusted me to test such an important component in an early version of mine.
What can the Skreemulator do?
It completely replaces the Skreem module (immobilizer) and also the central locking is controlled by the Skreemululator, the alarm module still works.
No Chrysler/Mercedes radio keys with transponder are needed anymore, a simple mechanical key like any locksmith can make is enough.
What can the OLED display do?
Standard display open/close, number of codes sent, code accepted, any error messages.
Display of speed, rpm, water temperature, engine oil temperature, transmission oil temperature, gear indicator with display of driving program, tank level in gallons, remaining range (roughly estimated), current consumption (roughly estimated).
Warning for too high water, engine oil or transmission oil temperature.
What changes in contrast to the original Skreem module?
the original radio key can no longer open/close the Crossfire this is done with the radio remote control of the included central locking module.
the transponder of the original radio key is no longer needed.
For whom is the Skreemulator?
First of all of course for everyone who has a defective Skreem module, then maybe for someone who wants to have his still working Skreem module (or the Skreemulator) as a replacement.
Finally, of course, for anyone who would like to have more information displayed.
The Skreemulator is available from me now.
I want to have a Skreemulator, what do I have to do?
Here is the manual, where everything is explained in detail: Manual
This is the scope of delivery:
Skreemulator:
Skreemulator with OLED display:
The display is installed here:
The trip meter is unfortunately no longer visible after installation.
Creation of the Skreemulator
Greetings, Andre
Old Jan 19, 2023 | 09:29 AM
MI1XFIRE's Avatar
Default Re: Skreemulator the Skreem replacement
Andre,
Congratulations on your accomplishment,and thank you for your long term dedication to the Crossfire community. These are great solutions for the Skeem problems on our cars.
One question,, I understand that they must be communication between the engine control unit (ECU) and skeemulator to start the vehicle. My question is, do you need the ECU for physical modifications or just programming?
Thank you and great work.
Old Jan 19, 2023 | 09:42 AM
Viper-666's Avatar
The ECU will only need for programming, no modification will be made.
As I sayed, I found also a way, that after this programming the original Skreem and the Skreemulator works.
Old Apr 11, 2023 | 12:19 PM
ABSAAL's Avatar
Hi, I am having issues with my car unlocking. Should this be able to fix it? My car's vacuum pump, key fob are working but my mechanic says the SKREEM module is the issue. Also, do you offer any sort of warranty or guarantee with your work?
Old Apr 12, 2023 | 02:49 AM
Viper-666's Avatar
Hi,
if the fault is really from the Skreem, my Skreemulator will fix it, but as there can be other problems like CAN bus errors, a defective BCM or defective wires there is no warranty that the Skreemulator will fix your problem.
Of course I give a warranty that the Skreemulator works but your ECU has to be programmed, so Rudy has to invest work in programming and testing, so I can't take all back if your problem with the locking system still exists.
Old Jan 24, 2024 | 08:34 PM
rtisor's Avatar
Hi, can I get your contact info?
Old Jan 25, 2024 | 05:48 AM
Viper-666's Avatar
You have a PM.
Old Feb 12, 2026 | 10:20 PM
Alindallastx's Avatar
Is this SKREEMULATOR still available and can this work be done here in the U.S. ?
Old Feb 13, 2026 | 04:36 AM
Viper-666's Avatar
Yes it is available in the US and I have a partner in the US who provides the service and support. For more Information please contact me over pm.
saltiga
Australia
May 7, 2023 05:04 AM
wolfstalker
Jun 14, 2020 05:55 PM
onehundred80
Feb 13, 2016 12:32 PM
britishcommando
Jan 7, 2012 04:26 AM
