PO is a POS
Old May 5, 2023 | 11:52 AM
Zen Beer's Avatar
Default Re: PO is a POS
Looks like it was a bad BCM, but have other wiring issues amazingly enough. Does anyone know if engine wiring harness are build sepcific or will anyone from same make and model work. Tired of soldering in weird places and several connectors are bad.
Alternatively anyone know where to find pigtail replacement connectors? Specifically in this case front right wheel speed sensor connector.
Old May 5, 2023 | 12:01 PM
Ronman's Avatar
Sometimes pigtail connectors have Mercedes part numbers. On eBay sellers have pigtails and wiring harnesses available.
Old May 29, 2023 | 06:31 PM
Zen Beer's Avatar
tracking down an abs wheel speed sensor and that should be all the wiring fixed. Now on to the PCM/ ECU service manual is telling me that it is not working, but I am a little suspect of that since it runs and drives fine. Just a mess of lights on the dash still. Anyone recommend a good ECU rebuilder?
Old Jun 5, 2023 | 05:15 PM
Zen Beer's Avatar
Anyone local I could test my DRB3 on just as a sanity check? Plano TX area?
Tomwas
Jun 25, 2021 10:56 AM
maggy55
Jun 1, 2017 08:07 PM
kuratsunade
May 5, 2013 01:08 AM
HRD2MIS
Dec 28, 2009 07:32 AM
kalel
Nov 11, 2009 06:50 PM
