throttle problems I think, HELP
Old Apr 28, 2023 | 04:13 PM
buddyrabon's Avatar
Default throttle problems I think, HELP
my 06 limited starts making a throaty noise when I press the gas pedal past half or hard exceleration . I took the throttle out clean it and replaced the o ring no improvement. could it be the built in position sensor? I can't find a new throttle body anywhere in the US.. any suggestions ive also replaced the m.a.p. sensor and the m.a.f. sensor as well as the crankshaft position sensor
MODERATOR NOTE: This is not an introduction, moved to appropriate forum.
Old Apr 28, 2023 | 04:54 PM
Default Re: throttle problems I think, HELP
If a little odd noise is all ya got, what are you worried about? Does the car run badly?
Got a CEL?
Old Apr 29, 2023 | 10:13 AM
zip439's Avatar
"A throaty noise when I press the gas peddle past half or hard" acceleration. It is hard to tell exactly what you mean. Is there a specific place you think the noise is emanating from?
Could be the previous owner altered the exhaust pipes or muffler. If you have no Diagnostic Trouble Codes, DTC then you should be fine. You can get free scans at most auto parts store, but they will try to sell you something you probably don't need.
slyfox1812
28
Jun 18, 2024 04:51 PM
HamdyHand
Apr 6, 2023 03:27 PM
Xenial
23
Mar 7, 2019 04:40 AM
crazyfred
Apr 20, 2018 04:22 PM
pburchette
Feb 23, 2014 11:23 AM
