Brake pedal goes down very far
Old May 11, 2023 | 10:20 AM
bhlavenka's Avatar
Default Brake pedal goes down very far
Brake pedal goes down almost to the floor 10 pump. It up works fine. I’m just wondering if this is normal which I don’t think it is and how to fix it.
Old May 11, 2023 | 10:36 AM
bhlavenka's Avatar
Default Re: Brake pedal goes down very far
Not sure if this got posted brake pedal goes all the way down and pump it up works fine. Brake level fluid is correct. Just wondering what I need to do to fix it.
Old May 11, 2023 | 11:50 AM
Romad's Avatar
More than likely a bad "brake master cylinder" or brake line leak or wheel cylinder seal gone bad. Looking around at everything should reveal where the leak is, if there is a leak. Otherwise I'd say the master cylinder is the culprit.
Old May 11, 2023 | 12:34 PM
Common issue with the Crossfire. Flush and bleed with new fluid. Usually bleeding the rears will resolve your issue. Owned 2 Crossfires, same issue, same solution.
Old May 16, 2023 | 07:06 PM
Romad's Avatar
How about a follow-up! Did you find and repair the problem?
Ed Mahoney
Jun 11, 2023 03:09 AM
MB04XFIRE
15
Jun 29, 2021 04:53 PM
Jim Holian
Feb 28, 2019 08:59 PM
Turbo-Duck
Apr 3, 2018 03:39 PM
smokey847
Jan 5, 2013 03:00 AM
