Crossfire coolant light on and AC not working properly
Old May 18, 2023 | 06:44 PM
Morgan March's Avatar
Default Crossfire coolant light on and AC not working properly
2004 crossfire 45k miles. This light keeps turning off in on in my car, supposedly it means coolant level low. Only issue is, my coolant is not low at all and I actually topped it off to try and get rid of this light. No luck at all. The AC keeps cutting in and out whenever the light is on. I took it to a mechanic this morning and they said they “checked everything and they can’t find a issue” thank the lord they didn’t try to charge me. I’m just wondering if anyone else on here has this issue
thank you in advance for the help!
Old May 18, 2023 | 07:39 PM
yorxs's Avatar
Default Re: Crossfire coolant light on and AC not working properly
This threw me for a loop also, I thought the light was indicating low coolant when the light only indicates a problem with the cooling system. It turned out to be the fan would sometimes stall out, which would also prevent the air conditioning evaporator from getting airflow making the air conditioning lukewarm. I recommend checking your radiator fan to see if it is spinning.
Old May 18, 2023 | 10:07 PM
That is not a low coolant light. That is a general cooling system alarm light.
IT comes on:
If coolant is low.
If coolant level sensor is bad.
If engine fan motor is bad.
If fan control module is bad.
MOST of the time, when it comes on, the A/C is disabled to reduce load on the engine and cooling system as a precaution to prevent overheating the engine. If your fan motor/controller are acting up, the light comes on and the A/C may cut out.
The most common cause is a bad coolant level sensor in the tank but we are seeing more and more Fan Control Modules fail as our cars age. IF you want a new one, the one from the Mercedes SLK320 (2003) fits. Ordering a Crossfire part usually results in "No longer available".
Old May 19, 2023 | 03:40 AM
mickolasjae's Avatar
If you’re leaking coolant I’d check the coolant reservoir to see if the nozzle has a hole or broke off (like mine did).
Old Aug 15, 2025 | 06:52 PM
Ferrarifan1's Avatar
well, I just recently had the same issue and I thought it was the coolant level sensor, I replaced that and got same thing, so I hooked my scan tool and threw me a code for the fan relay, the. I realized that the cooling fan wasn’t working and then I related the issue with the a/c problem, so I replace the cooling fan module, located on the driver’s side engine compartment close to the fender, that fixed my issues, good luck
sweetjamesjoness
Mar 30, 2018 04:46 PM
Skip19
18
Feb 1, 2018 08:22 AM
rjoyner17
33
Mar 19, 2015 10:59 PM
kixfire
May 26, 2013 03:58 PM
oswaldo
Jun 24, 2008 12:53 PM
