Won't Start
Old May 25, 2023 | 04:57 PM
jodyschiavo's Avatar
Default Won't Start
Hey Everyone,
I wanted to get your thoughts on this. I have a 2005 Crossfire Roadster, 40 k and in overall great shape. The car was sitting for 2 months and here is what I am dealing with:
  • Car has a new battery that is fully charged
  • Car took a few tries to start, did not try to turn over on the first few, then started
  • As I drove at low speeds down my street, seemed like the car did not want to shift into second. Kinda like when you have the gear selector in the wrong spot
  • I stopped the car to confirm the shifter was correct, placed into park
  • Once in park the shifter locked into park
  • I turned the car off with the hope of resetting, and..
  • The car refused to start, even try to turn over. I get dash lights and beeping for key.
  • I don't recall any serious dash lights, one for brake wear was lite.
  • I had the car towed to my home
Any thoughts on the issue, also, I live in Fort Lauderdale, any thoughts on someone to take it to?
Thanks!
Jody
Old May 26, 2023 | 05:05 AM
Viper-666's Avatar
Default Re: Won't Start
Normaly if the ignition switch is on it unlocked the P. All the errors you tell could be if the ignition switch is bad or if there is no power or ground connection to it. But your error that ist don't shift up could also be a problem with the shifter.
But as it is easier measure first if the ignition switch gives the right power in all positions.
Old May 26, 2023 | 08:52 AM
The battery or ground connection would be my suspects. Why did you need to charge the battery? Being "NEW" does not mean it is good.
Old May 26, 2023 | 09:50 AM
zip439's Avatar
Mat lives in Miami, he does a lot of work on Crossfires and will travel to you. Call him (786)877-5959
Old May 26, 2023 | 09:53 AM
Thanks everyone for your help! Great information
I am thinking of replacing the Relay Control Unit as a first step, appears that I could do that myself.
I will definitely reach out the Mat.
Jody
Old May 26, 2023 | 09:55 AM
Thanks so much, I am reaching out!
Old May 26, 2023 | 11:52 PM
tighed1's Avatar
Might be a bad traction control relay. Open the RCM and check that the 2 relays shown remain closed with the key in the ON position. Are they?
Old May 27, 2023 | 09:15 AM
Hey There! Thanks so much, Matt saved the day. He came up on Friday night to my place for a house call! Got it up and running! Love his passion for the car. I will be using him all the time.
I really can't thank you enough
Jody
Old May 27, 2023 | 09:17 AM
Thanks, everyone for their help. I really appreciate the support. Fixed!
Old May 27, 2023 | 09:31 AM
exparamedic's Avatar
What was the solution to the problem?
Old May 27, 2023 | 10:13 AM
tighed1's Avatar
And the problem was????
Old May 27, 2023 | 12:31 PM
She reported in yet another thread that it was the RCM.
She posted in at least three places on the forum. Not helpful but many newcomers here make this mistake.
Ptams
May 26, 2023 08:53 AM
agg1948@sbcglobal.net
Jan 7, 2023 02:20 PM
bamp
U.K.
Apr 29, 2021 10:27 AM
live2drive
Mar 4, 2012 09:48 AM
onefortypointsix
Sep 17, 2008 10:32 AM
