All warning lights on, key fob works, no code, crank no start
Old Oct 6, 2023 | 04:49 PM
Ronman's Avatar
Default Re: All warning lights on, key fob works, no code, crank no start
You have the wrong fuses on your RCM that's for sure. Only one should be 20 and the rest 15.
Old Oct 6, 2023 | 11:35 PM
Nefarious's Avatar
Good to know, I have no idea what the dude did to this thing but im sure theres multiple reasons its not starting
Old Oct 7, 2023 | 08:36 AM
Have you read post number 12? Did you try what it suggests?
Old Oct 7, 2023 | 10:54 AM
Nefarious's Avatar
I have, post #12 is my response explaining that the relays do come on when I turn the key. But now that im not getting spark to the plugs I'm gonna test the coils and all the wires headed to the electrical system
Old Oct 7, 2023 | 04:34 PM
Nefarious's Avatar
UPDATE:
I talked to my buddy and he said that I should unplug the OBD tester and try and crank it. It doesn't even try to crank without the tester in and the fan comes on. But the second I plug the tester in the fan shuts off and I can hear all the relays clicking on, so I'm assuming some sort of anomaly is happening where the OBDII port is acting as a ground or completing a circuit in the wiring but I can't determine in what module specifically. I'm gonna try and find a wiring diagram for the PCM, the RCM ect and try and trace the sourc of the issue
wish me luck
nicolas-e63
39
May 2, 2023 02:37 PM
JCJ
Oct 25, 2022 12:44 PM
No704
24
Oct 22, 2022 02:25 PM
MJinks
Dec 17, 2021 07:44 AM
projectmangaler
Sep 23, 2010 09:30 PM
