Help diagnose intermittent rough running
Re: Help diagnose intermittent rough running
Still getting the rough idle and no codes. Yesterday my fuel light started flashing. When i got home ran codes and got P0455. I've replaced fuel cap, fuel pump and purge valves already. When it warms up i think I'm going to pull the vapor canister. See if anything is broke or has a hole in one of the lines.
I have a XTOOL D7, it has the crossfire model. It scans then at the very end says it can't communicate with the ECU 😡
on
There is a vaccum port on the front underside of the intake manifold. You cannot see it. But you can get a few fingers on it. With the car running try to gently wiggle it and see if anything changes. If not spray some carb clean on it. If the idle changes, then that rubber piece that comes through the manifold is dry rotted. If it is rotten, There are a few options. You can push a small brass tube inside of it and then reconnect your vacuum line. Mine was so bad that it fell apart when I touched it. I either had to buy another manifold or fix it. Evidently that piece is not sold seperate from the intake. I pulled my manifold and split it open, then made a new piece. That job sucks. It takes 2 people to adhere it back together properly.
M60A3Driver (04-22-2024)
machfivecrossfire (04-30-2024)
Rotten vacuum hose at lower intake
This is inside of the intake where the hose plugs in
It was also not tite where it plugged in.
Combination of hoses and a brass tube. I was testing the fit for tightness. Adapter was installed on the short end of the bend after a test fit.
When installing. I had to insert just the hoses. And they should be very hard to get into the hole. Then I inserted the brass tube using lube. I inserted the brass tube past the hole as it made the vacuum hoses tight enough to seal. Also leaving enough inside for the control to make a tight seal.
I used mercedes sealant to seal the two pieces of the intake. And also coated the outside for extra protection and in case my fix was not tight enough. I let the sealant set up for 24 hours before reinstalling the complete intake. It is still holding just fine. This was in 2021.
Another thing is the factory piece was also rotten and cracked on the inside of the intake. It had a vacuum leak inside of the intake at the same time.
This is probably not your problem. However it caused most of the symptoms that you have been describing.
The following 2 users liked this post by machfivecrossfire:
M60A3Driver (05-02-2024),
zip439 (05-02-2024)
machfivecrossfire (05-02-2024)
on
M60A3Driver (05-10-2024)
HamdyHand
04-06-2023 03:27 PM
Selbyl
02-04-2014 09:31 AM
