Break NIGHTMARE! (pedal squishy & traveling)
Old Oct 23, 2023 | 08:17 PM
Default Re: Break NIGHTMARE! (pedal squishy & traveling)
Originally Posted by mikemadeit94
Thanks for the reply and checking yours! Im wondering if my booster is wheeping at that point but im also not sure how it actually functions to know..
Here's a post with a problem sort of like yours. It also has a diagram of the booster.
Here's the link: Brake booster
Old Oct 23, 2023 | 09:46 PM
mikemadeit94's Avatar
Appreciate that, maybe bad poppet valve from what im seeing? Not to sure.
Old Oct 25, 2023 | 10:28 AM
Did some research looks like it shouldn't be making that noise. Leaning towards a bad break booster downside is $499 new..
Old Oct 25, 2023 | 03:53 PM
Maybe take it to a Mercedes Mechanic and let him hear it. See what he says.
Old Oct 26, 2023 | 02:52 PM
Found another possible quirk.. the mechanic I took this to installed my front pads without clips.. I just took the risk and tried to order a low milage booster off ebay ill keep everyone updated thanks!
Old Oct 30, 2023 | 10:45 PM
I believe this is solved thank you everyone that put their thoughts together! The end of the day I had seized calipers in the rear that where shot, and the fronts where slightly seized I regreased and reinstalled and everything seems to be back to normal! Also believe I had a bad master cylinder but cannot confirm. After general maintenance bench bleeding the master etc everything seems to be back to normal.
Old Oct 31, 2023 | 09:49 PM
Thank you for reporting back, many do not. Lets hope this takes care of your issue long term!
onehundred80
Jul 24, 2022 11:10 PM
onehundred80
52
Apr 16, 2022 12:16 PM
Hurricane
Mar 19, 2016 03:32 PM
rayth
May 7, 2015 02:21 PM
meh03
Jun 12, 2013 09:07 AM
