In operative key fob
I changed the batteries the key fob and now it doesn't work? I've tried the procedure in the Owners manual, and procedures on you tube, and still, no luck?
any suggestions, besides going to dealer or key fob specialist. They're pricey!
inserted the key into the ignition 6 times and pressed the unlock button. It worked, after awhile.
thanks for your concerns and reply.
Also check to make sure you put them in correctly.
Here's a video:
onehundred80
Nov 15, 2022 05:13 PM
rrromine@aol.com
C-I-C-C-I Technical Documentation Collection
Apr 30, 2017 09:34 AM
