Starter Not Engaging On 1st Key Turn But Still Starts
Old Mar 24, 2025 | 07:39 AM
Reanz2112's Avatar
Default Starter Not Engaging On 1st Key Turn But Still Starts
Hi All,
Hopeing someone has experienced this issue and knows how to fix it.
Ive got an small intermittant issue with starting my 03 auto coupe that i cannot work out why its doing it.
Every now and then (usually at least once a week) i come to start the car and the starter doesnt engage straight away on the key turn. I turn the key and get a 'clicking' sound (usually between 2 and 6 clicks) and then the starter engages and the car fires up as usual. Runs fine until i shut it off and then i have the same problem starting it again.
The unusual part is that when i disconnect the battery, leave it a min and then re-connect the battery. The issue seems to resolve itself and the car then starts up fine on the 1st turn of the key. The problem seems to always return though and its at random time intervals between the disconnecting the battery and the problem returning.
Car does have a small battery drain but ive just replaced the battery recently and its currently holding a full charge.
Anyone come accross this issue or know what might be causing the problem?
Many thanks
Ash
Old Mar 24, 2025 | 08:14 AM
zip439's Avatar
Default Re: Starter Not Engaging On 1st Key Turn But Still Starts
Check all the connections AND the cables themselves in the starting circuit for corrosion damage: Negative battery cable to the fender, positive connection at the battery. cables to and from the alternator, check the ground strap below the engine from the frame to the engine. The battery itself could be problem, even when new some will have bad cells; get at the minimum a load test completed on the battery at an auto parts store. It rains a lot in England. I suspect corrosion/rust somewhere is causing your problem.
When all that is completed we can get into pulse module, RCM and starter.
Here is a link to battery drain problems: Finding what causes battery drain
Here is one on the starter: Is my battery bad?
I provide the links because your are new to the forum and welcome to you and hope you enjoy driving your Crossfire!
Please take the time to look at the forum layout and you will find much here to offer without asking. Each section have permanent sticky threads at the top of each section which overtime have proven to be most helpful from which much can be gleaned as to truly enjoying your car. Have fun.
Old Mar 24, 2025 | 11:28 AM
the fastest way to double check the battery is to turn on your headlights,,,wait 30 to 45 seconds ,,start the car if it is the batt. all u will get is clicking,, and the car will not start.
Old Mar 25, 2025 | 09:42 AM
Reanz2112's Avatar
Hi Both,
Thanks for coming back to me, ive tested the battery and that seems to be fine.
Ill move onto checking all the cables as you advised Zip thank you for your advice
Many thanks
Ash
Old Mar 25, 2025 | 10:04 AM
I would almost 100% guarantee it's the battery cables. I'd replace both positive and negative cable assemblies and also do James' mod at the same time:
https://www.crossfireforum.org/forum...le-engine.html
Old Mar 25, 2025 | 12:05 PM
also check the ground, it will it is under the exhaust manifold on the pass side
Drlehr1
17
Sep 18, 2024 07:40 AM
Romad
Jan 19, 2021 01:37 PM
grip grip
43
Jun 8, 2020 08:50 PM
deltacrossfirebob
33
Sep 21, 2018 07:35 PM
Keepmeinmind13
Jul 10, 2015 01:05 AM
