ECU damaged
Old Mar 24, 2025 | 02:16 PM
Pezcop's Avatar
Default ECU damaged
I have a 2005 SRT6 crossfire. The engine was having trouble. I pulled the ECU and saw that one of the areas that you plug the wires into it has several pins bent or broken. I sent it off to be fixed and they sent it back saying that it was too damaged to fix. I had previously had it tuned through MSS. No idea how the pins were damaged. Any suggestions on where to go from here?
Thanks, Don
Old Mar 24, 2025 | 04:12 PM
Default Re: ECU damaged
I would talk to MSS.
Old Mar 24, 2025 | 05:13 PM
Thanks, Don
I'm not 100% sure about this and hopefully someone else will chime in, but I think you can get an ECU from another car and it should work.
It has to match the car that it's coming from. Example: if you have a 2005 SRT6 Coupe it has to come from an SRT6 Coupe. If you have a limited roadster, it has to come from a limited roadster.
Old Mar 24, 2025 | 07:47 PM
xfClifford's Avatar
I emailed the owner (Pezcop)... Already advised him on his next steps. Eric and I have been helping him on & off lately.
Old Mar 25, 2025 | 09:53 AM
Pezcop's Avatar
Per Cliff and others I have a call into Josh at MSS. Thanks all.
Ninocrossfire
May 2, 2024 01:36 AM
smpshady
Jul 28, 2011 03:49 PM
lannyx
Feb 15, 2011 07:56 PM
samo59
Jul 29, 2009 12:43 PM
DanielNTX
Feb 14, 2008 12:15 PM
