Electric dead
Old Apr 2, 2025 | 03:00 PM
theglot's Avatar
Default Electric dead
So I drove a few blocks for a meeting and parked for 2 hours. Came out and put the key in the ignition and nothing. No lights. Have new battery, RCM only 6 months old.
Disconnected the battery and tried to think of what it could be. After 5 minutes connected the battery and everything was good. Anyone have any idea of what to look for?
Old Apr 2, 2025 | 03:30 PM
Default Re: Electric dead
Perhaps dirty or corroded battery cables. You need to check both ends of the cables.
Old Apr 2, 2025 | 03:46 PM
The fact you messed with the battery connections implies the issue is at the battery posts/battery clamps.
I get a picture of those posts and clamps might give us a clue.
But there is something - if it happens again, I understand you had no dash lights.
But if you turn the headlights on, do they come on? If not, I'd look at battery/connections. If they DO, then the issue is in the ignition switch or MAYBE RCM.
Of course, I am making assumptions, because 'no lights' is very vague, I know you think it isn't, but it IS vague.
Old Apr 2, 2025 | 04:53 PM
theglot's Avatar
Thanks for the suggestion.
I cleeaned everything so we will see if that solves the problem.
Old Apr 2, 2025 | 09:28 PM
This happened to me when I first got my car. The negative cable was loose at the battery terminal. I tightened both cables at the terminal and all was good.
Here's a tip: When you put your battery cables on after removing them, tap them down so that a little bit of the terminal is above the battery cable connector. Battery terminals are a bit conical in shape, so if the cables aren't seated correctly, vibrations from driving will make them slide up and lose connection. That's what happened to mine.
Old Apr 2, 2025 | 09:30 PM
theglot's Avatar
Thanks
Old Apr 18, 2025 | 12:02 PM
theglot's Avatar
It has been 16 days since I cleaned my battery terminals and cables and tightned the connections. No problems since. Thanks everyone for their suggestions.
Old Apr 18, 2025 | 05:17 PM
Thanks for coming back with the update.
my_car
Feb 14, 2023 01:28 PM
blacktouring
Aug 29, 2021 12:10 AM
Tbirdtony
37
Dec 11, 2019 09:07 PM
paandnana
Aug 31, 2012 08:43 AM
sive81364
Feb 26, 2011 07:55 PM
