Propshaft Center bearing
Old Oct 10, 2025 | 05:41 AM
2005_Coupe's Avatar
Default Propshaft Center bearing
Hi,
First post, some help needed please?
Can anyone tell me if the propshaft center bearing with carrier, is the same on Manual and Automatic cars ? I have spent hours searching but cannot find an answer.
I am in the UK and I have a standard (Not SRT) Automatic car. I am really struggling to find the correct part number and the old part doesn't seem to have any numbers on it. If anyone can help that would be great. Many thanks
Old Oct 10, 2025 | 07:09 PM
Default Re: Propshaft Center bearing
Originally Posted by 2005_Coupe
Hi,
Have you downloaded the free service manual in the documents collection? If you get to the section where the part is mentioned, you can then look up the part number through an online search. Once you find the Chrysler part number, look for the cross-reference to a Mercedes number. OR, lookup a 2004 SLK-320, I believe the part is the same as the crossfire N/A (Naturally Asperated). Good luck.
Old Oct 11, 2025 | 04:10 PM
NeedsWings's Avatar
here is the support and bearing we assemble.
it fits both the automatic as well as the manual transmission crossfires.
in stock and ready to ship to you.
https://www.needswings.com/driveshaf...rt-and-bearing
Old Oct 11, 2025 | 04:19 PM
Needswings is a well-known supplier and supporter.
Old Oct 12, 2025 | 11:38 PM
They are the same.
Here's my post on how I replaced mine:
Driveshaft support bearing and flex discs replacement
Old Oct 14, 2025 | 03:53 AM
2005_Coupe's Avatar
Hi, I have now found the service manual, which will be very helpful for future use, thanks. It has the part number for the prop bearing, but it appears to be discontinued.I know most parts are Mercedes SLK r170. Is the prop bearing definately the same as a SLK320 Auto. Some places I have read that Auto and manual cars have a different bearing, so confused !
Old Oct 14, 2025 | 03:54 AM
2005_Coupe's Avatar
They are the same.
This is brilliant, thank you. Just what I needed. Thanks to all who replied.
Old Oct 17, 2025 | 01:43 AM
Bearing is the same for both automatic and manual.
flightmedic
May 1, 2025 05:32 PM
MrMoPar
Sep 8, 2016 11:23 AM
Bucksnort
Apr 11, 2016 08:36 PM
mr.peebody_2011
Feb 21, 2015 10:26 PM
