Locking the back hatch without a remote
Old Nov 20, 2025 | 04:40 PM
Mallory Dean's Avatar
Default Locking the back hatch without a remote
Is it possible when I lock the doors with the key to also lock the back hatch? My remote doesn’t work and I was told by the locksmith it would cost a little over $1000 dollars to have a new remote made.
Old Nov 21, 2025 | 08:20 AM
zip439's Avatar
Default Re: Locking the back hatch without a remote
Using the key in the driver's door should lock everything including the rear hatch. When you twist the key in the door you should hear the air pump run briefly while the doors and hatch lock. Do you hear the pump run? If not then there is another problem other than the remote. You have replaced the two batteries in the remote I assume?
You can contact Needswings or Mercedes swap shop for new FOBS/keys. It won't cost $1,000.
PS let us know what part of which State you are in so we can better help you.
Romad
Sep 4, 2025 03:01 PM
Myopic
May 30, 2025 12:52 PM
Padgett
Jan 20, 2023 07:10 PM
carsmything
Oct 4, 2021 10:13 AM
carsmything
Oct 4, 2021 07:32 AM
