Wiper tank fluid leak (new spot)
Old Nov 25, 2025 | 01:54 PM
Mommasride's Avatar
Default Wiper tank fluid leak (new spot)
Happy Turkey Day to all.
We had our first cold snap down here in Florida a bit back and last week I noticed blue fluid on the floor under the Crossfire. Identified it as wiper fluid, got on the fourm to research and found that it most likely was a cracked tank. Opened up the wheel well to inspect and the tank looked good, however I noticed that there is a rubber plug in the lower side of the tank, maybe an unnecessary drain plug? In a previous post regarding the tank removal you can see it in the pictures. The plug was the source of my leak, it was a bit loose and has seemed to have contracted and not sealing all the way. My solution was to wrap the plug with a good rubber electrical tape that stretches, not the regular cheap stuff. I inspected the rubber grommet under the tank and it looked good but added some peel and stick rubber backing that I had to give it some added protection. So far the tank is not leaking. Sourcing a replacement plug might be a challenge but it’s similar to what you see in boat live bait wells or inner hulls, if the leak comes back that’s what I will try.
Old Nov 25, 2025 | 01:56 PM
Ronman's Avatar
Default Re: Wiper tank fluid leak (new spot)
Part number for the plug from Mercedes is 2109870045
Old Nov 25, 2025 | 07:47 PM
Mommasride's Avatar
Thanks Ronman.
Found one on eBay looks like is for optional MB headlight washer pump.
Old Nov 25, 2025 | 09:15 PM
Ronman's Avatar
Thanks Ronman.
Cheaper to buy from Mercedes dealership. The hole is for optional headlight washer pump.
Old Nov 26, 2025 | 12:30 PM
Nelson G's Avatar
Here is one: https://www.autohausaz.com/pn/MB-1708690320
Old Dec 3, 2025 | 08:03 AM
NancyAdolph's Avatar
Thanks for the link, you made my day.
Spoiler
LugNut
Mar 26, 2026 01:37 AM
Myopic
Apr 17, 2025 12:00 AM
Bayukbros
May 5, 2016 07:46 PM
goodgenes79
Dec 16, 2012 10:28 AM
Squirrel Crusher
Jun 1, 2009 12:01 AM
