Cannot remove supercharger pulley
Old Jan 10, 2026 | 10:38 PM
nickwe21's Avatar
Default Cannot remove supercharger pulley
Hi everyone!
Have removed the SC pulley many times on mine or friends cars. Never a problem. When I installed the 65mm pulley the OEM pulley came right off with a little bit of force.
I want to replace the bearing of the SC pulley. I tried for an hour tonight and I can't get the pulley off.
No idea why, but it seems to be seized in place.
It's not moving at all.
Are there any tricks or tips how to get the supercharger pulley off of the supercharger snout?
I have a gear puller but it's too big to get in between backing plate and magnetic supercharger clutch.
Any tip to get the pulley off the car to replace the bearing is much appreciated.
Thanks for any helpful ideas.
Have a great weekend,
Nick
Old Jan 11, 2026 | 09:42 PM
Default Re: Cannot remove supercharger pulley
Nick, try tapping the pulley in and then with two screw drivers try to move ir out (off ) just little also spray with nut buster or any penetrant
U may have to move it back and forth a few times before it comes off,,, about 10 years ago i had one stick, so bad i had to use nitrogen
to freeze the shaft and i small torch to heat the bearing, after i got it off i sanded the shaft , i think i took off .00001 thousand ,anyway
from then on i used anti seize on the shaft. jim
Old Jan 12, 2026 | 07:49 AM
nickwe21's Avatar
Jim you were spot on. Thing drive me crazy. Would not move an inch.
Let it soak with PB Blaster, kept trying and trying and eventually used a gear puller very carefully to get it going.
From there a little heat and it came right off. This was the 65mm IBF Poland aftermarket pulley.
The shaft had all sorts of "corrosion" and gunk on there. I think the bearing leaked and that stuff got heated up and seized the pulley in place.
I have a spare OEM pulley that came with the car and threw that one on there. I sanded the safe with a 2000 fine grit, used parts cleaner on it and got all that stuff off. Should be ok. I used a small amount of grease on the shaft so hoping this won't happen again.
I didn't have enough time but I have a new bearing sitting here. It seems to be the same as OEM NSK bearing.
I just don't have a press and there was not enough time to do the freezer/oven trick. I might just take the pulley and bearing to a machine shop and see if they can press it in for me sometime this week.
I am curious kind of to try it myself and see if 8 hours in the freezer and 45 mins in the oven would make this pulley really fall in that easily or if you still have to hammer it down.
Thanks for your help!
Old Jan 12, 2026 | 10:22 AM
Thanks, glad U got it off without hurting anything,, I did say i used anti seize on my shaft and now that i remember
i had to remove the pulley a year or so later and it did NOT want to slide right off,, got it off cleaned and sanded the anti seize,
and just installed clean,,, if the bearing started to fail and leaked some oil/grease then got hot that may have been the cause.
I don't think i have heard of any of the steel pullies from Poland failing jim
nation99
Jun 23, 2023 12:34 PM
nickwe21
May 11, 2023 05:53 PM
MoCross
Jul 29, 2018 10:08 PM
onehundred80
Dec 23, 2015 11:23 PM
