Preventive Maintenance
Old Feb 26, 2026 | 04:46 PM
NWGACarGuy's Avatar
Default Preventive Maintenance
After perusing our Forum and identifying most of the "quirks" and problem areas, I have either made the necessary repairs or taken preventive action to avoid unhappy surprises (which no doubt are out there in number just waiting...). I purchased replacement cam shaft and crankcase position sensors to keep as spares/back-up. I also downloaded and printed instructions for their repair. My question is this: Would it be a good idea to just go ahead and replace them now, in the comfort, safety and convenience of my garage? The car has 46k miles on the clock, and I just recently bought the car and cannot determine if the sensors are recently new. Are the replacement sensors bound to fail sooner or later anyway? If I can avoid surprise roadside repairs I would certainly like to. Opinions? Experiences? Advice? Thanks!
Old Feb 26, 2026 | 05:02 PM
Default Re: Preventive Maintenance
Carrying a spare RCM, in the trunk, is also recommend. The Relays wear out over time. They are plug and play and require no tools.
Index of Crossfire problems and repairs - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
Old Feb 26, 2026 | 08:41 PM
The cam position sensor is easy to replace because of it's location.
I replaced my crankshaft sensor at 48,000 miles in my garage before it went bad. I also keep another new one as a spare. I also wanted to have the experience of replacing it, in case I ever have to do it on the road.
Here's a link to the post I did when I replaced mine:
Crankshaft Position Sensor replacement
Old Feb 27, 2026 | 12:02 PM
I'd recommend replacing the Crank Position Sensor simply due to it's age
Be sure to use only a
BOSCH BOSCH
sensor as any other name is NOT reliable
BOSCH 0261210170 Original Equipment Crankshaft Position Sensor
The Relic
Nov 17, 2025 12:13 AM
KDW4Him
109
Nov 27, 2024 09:57 AM
rampntlion
21
Feb 11, 2019 08:18 AM
Mdcrossfire
Nov 25, 2018 04:05 PM
Greg Fiore
Jan 16, 2016 09:03 PM
