Belt Tensioner replacement
Old Mar 23, 2026 | 09:04 PM
nickwe21's Avatar
Default Belt Tensioner replacement
Very curious. Seems like the SRT6 belt tensioner pulleys aren't available anymore. What do you guys do once it wears out?
Can the N/A one be substituted?
Also have heard split opinions. Do you use the E10 torx to release belt pressure or a 15mm socket (the screw behind the torx)?
I tried the 15mm and am afraid I actually loosened the tensioner? Might be in my head buts it has a slight wobble and had too much play imo.
Should I tighten that 15mm screw or should I tighten the 2 screws that hold it in place?
But more importantly, if these aren't to be found new anymore, what are you doing if it breaks?
Old Mar 23, 2026 | 09:19 PM
Default Re: Belt Tensioner replacement
Maybe Rob at Needswings.com can hook you up with one.
Old Mar 24, 2026 | 10:28 AM
NeedsWings's Avatar
thank you for the referral, yes already helping through email.
Old Mar 24, 2026 | 04:22 PM
nickwe21's Avatar
Thank you guys!
Old Mar 25, 2026 | 04:52 PM
Nelson G's Avatar
But more importantly, if these aren't to be found anymore, what are you doing if it breaks?
Rock Auto and https://www.autohausaz.com/ have them. You just need to search under SLK32 AMG, and the price is reasonable.
Old Mar 27, 2026 | 12:47 AM
UrbanE's Avatar
Unfortunately, those would both be incorrect. The belt tensioners shown on both sites are for a non SC Engine
The belt tensioner for the M112K SC XF are out of production. They are not available anywhere. Best chance to locate a used one, is to contact Rob.
Old Apr 30, 2026 | 03:20 PM
nickwe21's Avatar
So, I am really confused at this point. We know the SRT belt tensioner is different from the N/A. The SRT6 one has the 10E torx, the N/A doesn't.
I cannot find the SRT Belt Tensioner ANYWHERE for the life of me, but I found the picture of the SRT engine, at the Chrysler museum (or at least some kind of display of the "original SRT" engine) and it looks to me like it has the N/A belt tensioner.
Can the SRT belt tensioner just be replaced with the N/A version? Or is there an upgraded one that looks the same? I need help finding this part. I do not have a larger Crank pulley, just a 65mm Supercharger pulley.
What's everyone's idea? I find it hard to believe that the unavailibility of the SRT6/SLK32AMG belt tensioner will send these cars to the junk yard.
Old Apr 30, 2026 | 03:45 PM
Rob at @NeedsWings has one - it is used but he wouldn't sell it if it wasn't in good condiotion
You can email him and see if he has a source for a new one too Sales@NeedsWings.com
https://www.needswings.com/used-m112k-belt-tensioner
Old Apr 30, 2026 | 03:57 PM
The one in the picture is the SRT6 tensioner. The N/A has a torx screw on the front and the pulley is different.
Old Apr 30, 2026 | 04:17 PM
NeedsWings's Avatar
thank you Gary,
i only have the used assembly, i thiknk @mr.peebody_2011 is sitting on a new one yet though that he may sell?.
Old Apr 30, 2026 | 04:23 PM
mr.peebody_2011's Avatar
I do indeed have a brand new M112k tensioner sitting in the box on my shelf. I also have two used tensioners. Feel free to shoot me a message here to the inbox or send me an email: zjoslyn13@gmail.com
Old Apr 30, 2026 | 04:51 PM
Will the Mercedes SLK32 tensioner work?
Old Apr 30, 2026 | 05:04 PM
It should, if it is on an untouched SLK32 OEM engine (used) and if a new engine part (check the year/engine either way). Good luck!
Old Apr 30, 2026 | 05:08 PM
NeedsWings's Avatar
yes, that is the one that is discontinued
Old Apr 30, 2026 | 11:53 PM
UrbanE's Avatar
And the question remains
No viable long term solution exists. A shrinking stock of used tensioners.
Used tensioner or nothing
I ran into this earlier and was fortunate enough to acquire a replacement and a spare from Rob
But longer term????
Old May 1, 2026 | 10:16 AM
Nelson G's Avatar
Look at this: https://www.rockauto.com/en/catalog/...ensioner,11659
It's listed for a 2004 SLK32AMG
or this one: https://www.autohausaz.com/pn/1122000970
Old May 1, 2026 | 10:46 AM
That is why I asked if the one for the Mercedes SLK32 AMG would work.
Old May 1, 2026 | 11:15 PM
nickwe21's Avatar
Question for me is, a lot of places list SLK32AMG/C32 AMG and they look similar at least, to the N/A tensioner. Do they fit? They cost a fraction of the cost outlined above.
What happens if one of those is installed? I’m just thinking there has to be a replacement option for less? Could be totally wrong though.
Old May 1, 2026 | 11:32 PM
Ok, silly question. Why wouldn't the N/A tensioner work on an SRT6 engine?
The mounting holes match up, I would think the pulley is the same size. The orientation looks the same.
Is it because the pulleys are made of different materials? Has this been tried?
Old May 2, 2026 | 11:31 PM
I would think not because the tensioner has to take a lot more stress. I sure wouldn't if I owned an SRT-6, if it does explode down the line I wouldn't want to have to fix it (iffin I had one)...
