Creaking Silver Console Trim
Old Apr 2, 2007 | 12:33 PM
slide93's Avatar
Default Creaking Silver Console Trim
Ok...somewhat minor annoyance but if anyone has successfully fixed this I'd love to correct it.
The piece of silver plastic that surrounds the shift **** has become loose over time (or perhaps was loosened after the TSB fix to the reverse lockout cable adjustment for 1st gear pop-out issues...which didn't fix it BTW). I know this is the source of the creaking noise as I drive because if I press my thumb down on the plastic behind the shift **** it's completely silent.
Any recommendations? Adhesive, noise dampening insulation, etc? How easy is it to take off this piece around the shifter to get at the problem?
Thanks!
Old Apr 2, 2007 | 01:33 PM
AMGLover's Avatar
Default Re: Creaking Silver Console Trim
Deleted Message
Old Apr 9, 2007 | 09:33 PM
No Warning Shot's Avatar
If it's like mine, just make a downshift from 6th to 5th and it'll come off. German engineering at its finest.
Old Sep 21, 2007 | 08:10 PM
SRT-6 Steve's Avatar
Talking Re: Creaking Silver Console Trim
Thanks!
I had a lot of creaking noise from the silver section of the dash and center console. You just push on it and it drove me crazy. I used WD-40 on all seams where the pieces fit together. It pretty much eliminated all noise.
Steve
Old Dec 2, 2008 | 06:27 PM
jarrod08's Avatar
i wouldnt use wd- 40 because it will dry your plastic out and cause it to crack, might use silicone lube or graphite lube in aresol can.....
Old Dec 2, 2008 | 06:29 PM
SRT6nTulsa's Avatar
1. Disassemble
2. Place sticky-sided felt to contact areas
3. Reassemble
I installed a high power subwoofer and did this for my entire trunk area, which is prone to creak/rattle/squeak. I haven't had any problems.
Mackel
Oct 16, 2015 09:03 AM
Canyonero
Oct 6, 2015 09:23 PM
nataliefs
Oct 5, 2015 01:03 PM
Mackel
Sep 29, 2015 02:41 PM
55chevy
Sep 13, 2015 07:38 PM
