Severe Humidity Inside Cabin
Old Sep 7, 2007 | 04:01 PM
BillP2R's Avatar
Default Re: Severe Humidity Inside Cabin
Yes, I'm sure that the end of the return spring that is supposed to pull the linkage back over center is no longer attached to the outside of the housing where it should be. Apparently the plastic anchor point molded onto the outside of the housing to retain the end of the return spring has broken off.
It took me several afternoons learning how to disassemble the instrument panel/dashboard (errors in the service manual didn't help) to the point where I could determine the problem and manually get the linkage over center so the door could be positioned in the fresh air position. (Because the linkage goes over center, just removing the blower motor and reaching up to the door does not allow repositioning of the door when in the recirculate position).
- Bill
Old Sep 7, 2007 | 04:18 PM
maxcichon's Avatar
The "Rest Mode" as I understand it, makes residual heat available to the cabin when the engine is "OFF".
Old Sep 10, 2007 | 10:56 AM
ARS-FIRE's Avatar
I live in southwest Washington and the humidity stays pretty high. Fogging is a situation I have discovered in my '04 Limited coupe. Whenever I roll down the window the windshield starts to fog if I have been running the AC. I don't drive the car often enough to figure out why and its hard to read the manual in the dark on the highway. And now, from reading these posts my mind is starting to fog...
Old Nov 3, 2009 | 01:46 PM
dejohnny's Avatar
Originally Posted by maxxm
Here is some info from page 126 of the owners' manual.
Now this whole mystery is beginning to make sense. Thanks maxxm!
55chevy
Jul 22, 2024 02:31 PM
franklindm
Mar 14, 2020 12:23 PM
TerryR
Dec 13, 2019 03:27 PM
eatmycrackers
Sep 23, 2015 09:08 AM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
