Headlight Replacement - SRT6
Old Feb 4, 2009 | 08:04 AM
Substantiated's Avatar
Default Headlight Replacement - SRT6
Hello All,
I'm replacing my headlights with new OEM units...not the bulbs, the entire units (due to cosmetic damage). Does anyone have documentation/information/suggestions on same? I'm trying to avoid purchasing a service manual at this time. Thanks!
Old Feb 4, 2009 | 08:21 AM
Thumper SRT6's Avatar
Default Re: Headlight Replacement - SRT6
You can get a PDF of the service manual in this thread in the SRT section:
https://www.crossfireforum.org/forum...ad.php?t=13875
Old Feb 4, 2009 | 08:28 AM
maxcichon's Avatar
I just had mine replaced at the dealership. Here is a link to the .pdf invoice I posted:
https://www.crossfireforum.org/forum...183#post335183
At least it has the #'s-it might help?
Also-the headlamp assemblies are identical for all models (SRT, Limited and Base) of the crossfire. At least in the 'states.
Old May 9, 2009 | 11:43 PM
mikenewb's Avatar
Are the headlamps a single unit? Is there anyway to get inside of the casing without cutting into it? I want to put a Audi LED light bar at the inside base of the headlight casing and was wondering if theres a hole or could remove one of the headlight bezels to feed the tube into..Any infor would be appreciated!
Old May 10, 2009 | 07:18 AM
Paul Bosslet's Avatar
Hi,
Do a search on the subject "angel eyes"; there are full instructions on headlight disassembly.
Old May 10, 2009 | 07:21 AM
bluecoupe's Avatar
The headlamps are a sealed unit, there are number of threads on the topic. One of our UK members has recently posted his Angel Eyes mod.. Here's a link to a pretty good write up, although it's not a Crossfire, the process is the same:
Angel Eye Modification
Also, here's a link for the LED strips:
Audi R8 Style LED Side lights Grand Cherokee Crossfire on eBay, also, Chrysler, Car Parts, Cars, Parts Vehicles (end time 03-Mar-09 22:01:34 GMT)
Old May 10, 2009 | 07:37 AM
cassidyrj1's Avatar
What are you doing with your old headlights? I am looking for some to play around with.
Old May 21, 2009 | 02:55 PM
Montana Crossfire's Avatar
[IMG][/IMG]To Remove Crossfire headlights...
standing in front of the car look at the front end?
Now, Remove everything you see!
The least user friendly headlight removal in the Auto Industry
But, I Do LOVE THIS CAR!
Mike
]Message - CrossfireForum.org Gallery[img]
Old May 21, 2009 | 03:33 PM
waldig's Avatar
Talking Re: Headlight Replacement - SRT6
I have done it several times with and without the front end on. Front end off is easier.
There are two GOTCHA 10 mm bolts per headlight on the I Cant see them Bottom. Must get up close and personal from the BOTTOM to access them. Removing the splash shields on the inner fenders allows access. Again front end off is easier.
On my lift the front end comes off in about 10 minutes, pull wires and un do the 10mm bolts -------------its off, tough the first time.
Leaning toward the weekend.......................Woody
Old May 22, 2009 | 07:41 PM
Raj's Avatar
Raj
Assuming that the SRT6 has the same headlights as the other models, it is a Technical Service Bulletin (TSB) and will be replaced by the dealership if you tell them that the lights are defective and there is a TSB for them. The dealership I go to tried to have me pay $800 for one blown unit. I argued that it blew because moisture was in the light and therefore it was a defect in the design. They replaced it but charged my $100 for labour. At first I was thankful. Later, I found out there is a TSB on the headlights and went back to get the other side replaced for cosmetic reasons. Once I said that it is a TSB it cost me nothing and no questions were asked. Good luck.
Old May 29, 2009 | 12:39 PM
jsaredwings's Avatar
If the cars still under warrantee have the a chrysler dealship check them out, i had my o5 srt6 headlight units replaced and where covered by the warrantee, mine had hazing, continuous moisture, and minor discoloration, they were twice as bad as my 98 corrolla. dealership stated they had very poor seals which are a common problem with the car. not sure if thats what you meant by cosmetic damage but good info for anyone else with a similar problem.
Old May 29, 2009 | 09:10 PM
ZeroZero's Avatar
Hi All
I have just today replaced my headlamp units , I jacked up the front ,took front wheel off ,unscrewed the front of the wheelarch covers & pulled out of the way , removed two bolt/nuts from bumper to fender , remove two lower headlamp bolts , removed two upper headlamp bolts ,removed two upper bumper bolts (star heads) ,remove grille , took out side light (UK) + two cables back of units & that was it , pull & roll headlamp unit watching lower adjuster bolts as could mark the bumper do not take adjuster out of unit or your lights will be out of line . the first one took me about 1 hour the 2rd about 20mins , hope this help someone .
Cheers
Andy
Old Oct 4, 2009 | 04:06 PM
samer2thamer's Avatar
If anyone has a right passenger headlight laying around or for sale I would absolutly love to have it. Please send me a pm. I crashed my car into a stop sign while I was drifting in the rain yesterday and now i need some parts . I cant bear looking at my car from the aftermath.
Kodebuster
Nov 5, 2020 04:06 PM
jgreen
106
Sep 18, 2017 11:46 PM
RED DOG
Jul 22, 2015 08:55 AM
axnguyen
Jul 21, 2015 11:41 AM
Beeker
Jul 20, 2015 03:46 PM
