How to Always on Electric Coolant Pump SRT
Old Jul 1, 2018 | 03:38 PM
  #41 (permalink)
KDW4Him's Avatar
Default Re: How to Always on Electric Coolant Pump SRT
Originally Posted by CapnRon
You reckon the HWKO (Hot with key on) lug... would be safe to support running the cooling fan for short trips around town while I wait for my cooling fan relay module to arrive...?
You might want to start a new thread asking that, someone might know how to bypass the pulse module for the fan.
Old Jul 1, 2018 | 03:50 PM
  #42 (permalink)
The engine cooling fan is fused at 50 amps and I believe a full-on fan motor runs around 30 amps.
I'd say no.
Old Jul 1, 2018 | 04:26 PM
  #43 (permalink)
CapnRon's Avatar
Well ok... then I need a mod/bypass to make the fan run with the key on.
Old Jul 1, 2018 | 04:28 PM
  #44 (permalink)
CapnRon's Avatar
Indeed. Will do.
Old Jul 1, 2018 | 05:37 PM
  #45 (permalink)
waldig's Avatar
Talking Re: How to Always on Electric Coolant Pump SRT
Fan runs with about 4 volts and goes higher with heat in radiator.
Iam here to tell you the fan wont last and will startle you if you direct connect it to the battery, it STUNNING at 12 volts, been there and done that.
Try it at your own risk, at 50 mph it is doing nothing anyway considering the forward motion. Enjoy Woody
Old Jul 1, 2018 | 07:57 PM
  #46 (permalink)
CapnRon's Avatar
Gotcha... makes sense. Thanks for the heads up.
Old Aug 13, 2019 | 03:57 PM
  #47 (permalink)
Fla_Xfire_SRT's Avatar
Sometimes, with the AM radio on , when I first pull out of the driveway, after a first start , at around 1250 to 1300 rpm's, you can hear what is probably either the pump or the supercharger through the radio speakers. But yoou only hear it once.
Old Aug 15, 2019 | 06:25 PM
  #48 (permalink)
Through the speakers?
BrenLW
Aug 5, 2015 04:53 AM
axnguyen
Jul 21, 2015 11:41 AM
Beeker
Jul 20, 2015 03:46 PM
Tp'sfury
Jul 17, 2015 01:15 PM
ja.nko
Jul 10, 2015 03:21 PM
