How to Repair Relay Control Module (RCM) - (Mystery no Start)
Originally Posted by michaelcamilo
Update: Going on 3 weeks with out my Crossfire. Been riding the guzzi to and from work everyday.
I had the car towed from Superior Auto Clinic in North Hollywood to Dave Ellis Chrysler in Canoga Park. I relayed the history of the issue to the service manager who did not tell his certified crossfire tech as he wanted him to diagnose the issue blind.
They've come up with the same thing I did, "Code 2071-08 Start enable from SKREEM not sent."
He says that this is a known issue and there is a "Star Case" number that was issued just this August.
The protocol is to replace the SKREEM module; parts + labor $620. Ouch.
Hi All
Just thought I would add my 2 pennies (or cents of course) to this thread.
Just started getting the 'no start' problem in the last month and this thread has pointed me towards the RCM (thanks!).
In my case what happens is you turn the ignition but sometimes (and only sometimes) the display does not go from the # type sign to the P sign for Parked. If it does not go to P the ignition doesn't crank at all. Sometimes you can just wait and eventually the P comes on - more recently it has started flickering between P and the # sign meaning a great game of chance as to when to turn the ignition that last turn!
When it does start the Spoiler goes up and requires lowering if the above circumstance has happened.
Anyways opened up the RCM and checked the solder joints - they look OK to me - not a overly large amount of solder but looks like full contact there and enough solder to do the job.
However, and heres the rub, the actual relay on the same 'end' as the solder joints in question was covered in 'gunk' - cleared this down and the spring either broke whilst cleaning it or was broken anyway (I suspect the later since the remainder of the spring was hardly what I would call spring like) - it looks like some kind of corrosion in there.
Have ordered some springs to arrive tomorrow (not sure if I have the right size but we will see) and cleaned up as best I can so will let you know if that cures the problem - it seems a 'similar' problem but not down to the solder joints in my case!
On the bright side a new RCM in the UK is only £120 (I say 'only' but I mean compared to the $700 I have seen on this thread being quoted to replace the RCM at a dealers).
Cheers
Dave
Oh and something else! Mine has 07S written on the PCB - is this the mod to fix the solder joints do we think?
Cheers
Dave
look at those joints under a magnifying glass..they aren't soldered that well...I would solder them since you have it out. I think Dave has dealt with the relays you are talking about...as well as DJ...that would be 180 and tighed1...
I don't have a magnifying glass but have looked as close as I can with the naked eye - also with my track record of soldering I think I would prob be better off buying a new RCM! ;-)
Hopefully though my problem is the Relay so I won't have to!
R.
Dave
Originally Posted by Dave Myers
Thanks for the reply
R.
Dave
R.
Dave
Originally Posted by Larry Hitze
Dave, contact Tighed1 he will work out doing it for you. See post # 120 in this thread.
Thanks but I am in the UK so thats a no go I am afraid - don't worry will sort it myself if I have to - lets see if the spring and the clean-up does the job.
The post office still works there in the winter doesn't it?
Anyways springs have arrived and with a bit of creating wire cutting have managed to make one fit the relay - have also done the solder fix (badly of course) and she is firing up first time now - time will tell if it holds I guess. Will probably buy a replacement from MB anyway and use my 'fixed' one as a backup just in case (I never trust my own fixes for long!)
Thanks for all the advice
Dave
My car electronics work fine, and I hear the ignition ticking when I turn the key. But the car will not crank at ALL. That lead me to think I might have an RCM problem. However I am suspicious because just this morning I put my Mopar battery on a trickle charger, charged it to 100% (Voltmeter read 12.6 to 12.7 Volts), cleaned the battery terminals with a baking soda/ water mixture, and reconnected the battery. I turn the key and no crank. I then double-checked the + and - connectors/ terminals and noticed the negative connector that goes to the frame had a ring of "reddish tint" on the bottom of the loop where it connects to the battery terminal. Re-scrubbed and dried the connectors, but the color appears to be permanent.
I find it to be a strange coincidence that the car will not crank right AFTER I charged the battery, yet the symptom does seem to be identical to the RCM problem...
I'm looking at my RCM board as I type this, and the soldering looks to be in good shape. Any ideas would be greatly appreciated, as the car is my daily driver and work starts bright and early tomorrow
Are you using a magnifying glass to look at the RCM solder joints?
I am not into coincidences either, but you never know.
Am I the only one that believes in wire brushing or lightly sanding the battery terminals and connectors? Shiney connections are happy connections
Thanks for posting up this easy fix. I was doing some other mods under the hood anyway so I decided to go ahead and check on my module. Guess what I found?! A min later with the soldering iron and I prevented a problem before it started thankfully! I guess it should become an annual inspection item to make sure I dont run into problems in the future.
Thanks again for sharing the valuable info!
Glad you were able to DIY before a problem happened and before the price goes up for me to fix them.
Since little stickers are now going for $10 each ($13 if yer from Canada, eh) I must not be charging enough!!!
No really, still JUST $10 ($5 for return shipping & $5 for a beer) for this service to my Crossfire friends (NOT customers).
Nice to see that "you're" not here only for the money !!!
