TSB: April 2004 - Radiator Inlet Hose
Old Apr 21, 2004 | 11:51 AM
DFWSBR's Avatar
Default TSB: April 2004 - Radiator Inlet Hose
The issue:
Some vehicles built prior to February 16, 2004 might require a slight adjustment to the radiator hose.
The inspection:
Dealer can inspect radiator hose to ensure it is not contacting the radiator fan shroud.
The fix :
Hose clamp can be loostened and hose can be adjusted to meet proper clearance.
If you choose to perform a visual inspection on your own, make sure the car is cooled off. (for obvious reasons) Next time you are at the dealer, have the tech take a look. A majority of Crossfires built will not require any adjustment.
Old Apr 29, 2004 | 11:42 AM
Jamikest's Avatar
Default
This is Recall D11
Old Apr 29, 2004 | 02:12 PM
DFWSBR's Avatar
Default
Number: RC-D11-04
Issue D: 04/2004
Models : 2004 ZH (crossfire)
Subject: Radiator Inlet Hose
syfi
Mar 28, 2026 04:14 PM
franklindm
Mar 14, 2020 12:23 PM
paine2907
Oct 2, 2015 10:01 AM
crossfireE
Oct 2, 2015 01:40 AM
maxcichon
Sep 28, 2015 07:34 AM
