oil leak
Old Apr 2, 2011 | 04:22 PM
rvd4now's Avatar
Default oil leak
hey is there a tsb for the leakey oil gaskets.. if so please let me know
Old Apr 2, 2011 | 05:16 PM
Default Re: oil leak
I'd try a search in the SRT6 documention thread.
Old Apr 2, 2011 | 08:51 PM
Here's probably one of the better threads about the valve cover oil leaks.
Old Apr 3, 2011 | 05:17 PM
rvd4now's Avatar
hey i still need to no if there is a tsb on this... i need to give it to the dealer who has no ideal what the hell hes doing
Old Apr 3, 2011 | 05:22 PM
bluecoupe's Avatar
Mine were replaced under warranty, no tsb that I know of. BTW, why would you take it to the dealer if you know that they don't know what they're doing? Isn't that asking for disappointment?
Old Apr 3, 2011 | 05:24 PM
rvd4now's Avatar
this is true.. lol
Old Apr 16, 2011 | 01:51 AM
nelsonadams's Avatar
The same thing happened to my crossfire 05. Found out oil leaking from it, and the other one was on the pan. I remember I hit something on the expressway about 3-4 days ago. It's a small leak and will be going to the shop on tuesday. I do have a 7/70 warranty on my car, but not sure if this would be covered, and since my deducible is only $100 would it even be worth it to file. I put some High Temp RTV on both mating surfaces of the exhaust donut and re-installed and everything went fine. In your car i highly recommend going going to the dealership...They have the list of technical service bulletins there.
Old Apr 16, 2011 | 01:32 PM
dtinker's Avatar
My LTD 2006 Roadster was leaking at the little covers to the valve covers. I bought some high temp RTV, cleaned the surfaces, chased the threads with steel bolts and used the aluminums to close up. Just put on evenly and loosely, let the RTV set up then tighten ( Just snug), to tight and the aluminum bolts will break. No leaks now. There is a thread about oil leaks at the valve covers, that's where I found out about it.
TerryR
Dec 13, 2019 03:27 PM
minimayhem
16
Aug 23, 2016 07:47 AM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
