serpentine belt replacement
Old Jan 21, 2018 | 05:36 PM
  #41 (permalink)
Default Re: serpentine belt replacement
Old Jan 21, 2018 | 05:38 PM
  #42 (permalink)
Originally Posted by mariontr
OK, I need help the belt came loose and followed directions to put the new one on but looks like something is missing, see pictures attached. 2004 Xfire
Looks like the belt tensioner pulley is missing to me.
Old Jan 21, 2018 | 05:43 PM
  #43 (permalink)
Steve Jr's Avatar
From what I see, nothing is missing. In the picture, to the right of the middle, lift the idler pulley, route the belt, release the idler pulley down (it has a heavy spring behind it) an that adds tension to keep the belt onto all the pulleys. You should have a diagram in front of the radiator of how it is to be ran.
Looking at it again, it does look like it's gone.
Old Jan 21, 2018 | 05:45 PM
  #44 (permalink)
Agreed :
https://www.ebay.com/itm/URO-Parts-1....c100677.m4598
Old Jan 21, 2018 | 06:00 PM
  #45 (permalink)
The diagram was an optional extra. LOL
Someone who shall remain nameless had a good idea, a couple of guys here got some made and sold them to people who wanted them, $5 extra to Canada.
Old Jan 21, 2018 | 06:04 PM
  #46 (permalink)
See post #32 for what the tensioner should look like.
Old Jan 21, 2018 | 06:06 PM
  #47 (permalink)
Steve Jr's Avatar
Look at post #3 , to see what it's suppose to look like.
I'm writing an your answering.
Old Jan 21, 2018 | 06:19 PM
  #48 (permalink)
I supplied a link in post #44 that has the picture AND a price of $24.95.
What more can I do ?
Old Jan 21, 2018 | 07:02 PM
  #49 (permalink)
Find him the pulley, that is what is broken apart, cheaper than the whole assembly. The tensioner on my NA had a cylinder on it as well. Never did look into its reason.
Old Jan 22, 2018 | 07:19 AM
  #50 (permalink)
Never have seen the pulley listed separately for the NA.
That cylinder is found only on the 2004's, must have been something to do with harmonics in the belt,
at any rate they dropped it in 2005-
Old Jan 22, 2018 | 08:50 AM
  #51 (permalink)
The pulley is out there, it is mentioned on this forum.
Old Jan 22, 2018 | 08:59 AM
  #52 (permalink)
mariontr's Avatar
Thanks everyone for the awesome replies, So if I get just the pulley how easy to replace or if I get the whole assembly what will it cost. Looking at Rock Auto for the belt tensioner pulley and all shows a grooved one not the smooth one as shown in the posts here
Old Jan 22, 2018 | 09:12 AM
  #53 (permalink)
mariontr's Avatar
Well will order this since it was new, rather than the used one that ala_xfire posted
Amazon Amazon
Old Jan 22, 2018 | 09:31 AM
  #54 (permalink)
Wise choice, didn't realize the one I posted was used. Need to wake up
Old Jan 22, 2018 | 09:45 AM
  #55 (permalink)
Once again, you are correct. Found just the pulley in Hong Kong for $10 - ordered one.
Old Jan 22, 2018 | 09:55 AM
  #56 (permalink)
It is a good idea to put the part number on the forum for all to see in the future.
I have some numbers but I am double checking them.
Old Jan 22, 2018 | 09:59 AM
  #57 (permalink)
I will wait until it arrives and I can verify it is correct, then I'll post the link.
Old Jan 22, 2018 | 12:11 PM
  #58 (permalink)
mariontr's Avatar
Now just in case something goes bad wrong, do you have a part number for the E12 Torx bolts? Trying to cover all bases
Old Jan 22, 2018 | 03:37 PM
  #59 (permalink)
He has an ‘04.
Pulley 88mm OD x 17mm ID x 25mm wide. CLICK
Old Jan 22, 2018 | 08:27 PM
  #60 (permalink)
My fairly early 2004 does not have the cylinder...
