Cam shaft sensor
Old Oct 5, 2011 | 07:46 AM
dennisoates's Avatar
Default Cam shaft sensor
In regards to the camshaft sensor, what tools are needed to replace? Can i somehow get Chrysler to warranty this for me, Im still covered under the ext service contract. What are the symtoms of it being bad? I am driving from Michigan to Florida and back soon.
thanks in advance
Old Oct 5, 2011 | 08:38 AM
Default Re: Cam shaft sensor
thanks in advance
Tools : E8 Torx socket ( or in a pinch, 6mm / 5/16 socket )
Symptoms : sucker won't start, or if already running - it dies suddenly.
Warranty most likely won't cover unless the sensor has already gone bad.
( or you are buddies with the service tech )
This sensor is a 'Hall Effect' transistor that is triggered by a magnet in the end of the camshaft.
As such, they usually just quit suddenly, no sputtering etc .
On the other hand, the Crankshaft Position Sensor is an 'inductive' sensor, sputtering, failure to start at times can occur from this one.
They should be treated as a set, when you replace one, replace the other one too, and keeps spares in your travel kit along with enough tools to replace them yourself if you are in the middle of the boonies ( and don't have AAA )
Old Oct 5, 2011 | 12:37 PM
thanks in advance
These sensors are not too much trouble based on the posts on this forum, the crankshaft position sensor and the relay control module are the worst problems seen.
Old Oct 5, 2011 | 01:08 PM
LantanaTX's Avatar
At least the CPS sensor is fairly easy to change. coming home from the Dragon I lost the speed sensor that is INSIDE the transmission and is not sold separately. you have to buy the whole conductor plate. Symtoms are stuck in one gear, no speedo, plenty of lights lit on the dash! since I ahve to drop the pan to fix, I am doing a full service this weekend. I am even going to fix the famous trans leak that I have never had and install the blue top solonoids while I am in there. I want to nominate the speed sensor to worst problem status!
Old Oct 5, 2011 | 01:12 PM
hcarter's Avatar
39.00 Ebay Works perfect. made in Germany .
Old Oct 5, 2011 | 02:15 PM
Howard, that is the same exact package mine came in, and won't work, a replacement is on the way.
No where does mine say Germany.
Old Oct 5, 2011 | 02:37 PM
hcarter's Avatar
Wow I will go home this afternoon and swap them out and make sure it is the right one , one thing i dont need is a bad part if i need it on the road ,, are they sending you a different part number all together ?
Old Oct 5, 2011 | 03:55 PM
It is the correct part. Just a bad one I guess. Yes they are sending the same part number. James
Old Oct 5, 2011 | 04:10 PM
Go Bosch or go (walk) home.
Old Oct 5, 2011 | 07:51 PM
hcarter's Avatar
James I installed the one I have and it works fine no problem car fired right up ,so I guess you got a bad one ,,,,,, but thanks for the heads up ,,,you never know.
Old Oct 5, 2011 | 08:54 PM
Howard, glad to hear that. I will see when mine arrives. Thanks for giving it a try and posting a note.
James
roar
Jun 15, 2022 11:46 AM
rampntlion
21
Feb 11, 2019 08:18 AM
cjw
Oct 26, 2015 10:26 PM
ala_xfire
Sep 28, 2015 05:51 PM
cjw
Sep 27, 2015 10:22 AM
