Bad sound. Help me tech guys.
Old Jul 9, 2012 | 08:40 PM
Mr. Max's Avatar
Default Bad sound. Help me tech guys.
I HAVE THIS HORRIBLE SOUND COMING FROM MY FRONT END. It sounds like an air horn going off. It's only happened three times and I can't make it do if I try. It seems to happen at low speeds when I put on a little gas. It's very brief and I thought it was a semi truck blowing it's horn the first time I heard it.
On a less serious note my A/C PUTS OUT COLD AIR SOMETIMES AND OTHER TIMES NOT. The settings are right/switch on. I don't get it.
Thanks.
Old Jul 9, 2012 | 08:46 PM
Mr. Max's Avatar
Default Re: Bad sound. Help me tech guys.
Oh yeh, on the A/C thing. Not talking about fan problems and the coolant temp isn't elevated.
Old Jul 9, 2012 | 09:33 PM
waldig's Avatar
Talking Re: Bad sound. Help me tech guys.
Noise sounds like the boost is blowing out of a gasket or hose. A/C well that compressor could be shutting off due to a lack of freon, try buying one of the simple gauges and see what the pressure is while ideling. You need a midget to get under your hood to monitor the issues. Woody
Old Jul 9, 2012 | 11:45 PM
Thanks.
The noise could be a pulley starting to seize up and the belt slipping over it, look at the belt for scoring and burn marks.
Old Jul 10, 2012 | 03:20 AM
Mr. Max's Avatar
Thanks guys, I'll check those possibilities out.
steps
Oct 13, 2015 06:18 PM
o55ie18
Oct 5, 2015 05:50 PM
Oct 1, 2015 01:42 AM
debradegiovanni
Sep 27, 2015 09:39 AM
grip grip
Other Cars Etc
Sep 26, 2015 09:52 PM
