srt wont shift
Old Jan 22, 2019 | 05:23 PM
rednrollin's Avatar
Default srt wont shift
I have posted this problem in the past where my srt the check engine would inadvertently come on and not allow the car to shift at certain times. When this occurred in the past, and I was able to get it to reset by turning the engine off then back on and if that didn't work, I could get it to work again of unplugging the battery. This would also reset the check engine light. I was told here that it was probably the inter cooler pump which I then changed and made no difference. Now the check engine light has come on and it feels like I have no power and in the drive position it wont shift or allow me to manually downshift Any ideas? Thanks Mike
Old Jan 22, 2019 | 06:28 PM
Default Re: srt wont shift
Have you looked for any codes that may have been set?
Old Jan 28, 2019 | 09:03 PM
rednrollin's Avatar
Yes P0715 Input/turbine speed sensor. Looking for one now
Old Jan 29, 2019 | 12:41 AM
What you need to look for is a 722.6 "conductor plate" replacement kit. FCPEuro offers one and several on eBay.
I think Rob at needswings.com also has them.
Old Jan 29, 2019 | 01:34 AM
rednrollin's Avatar
Thank u Bigtime! Looks like I can install except for the computer downloads. Is that correct?
Old Jan 29, 2019 | 05:15 AM
Computer download?
The TCM does NOT need to be upgraded.
Old Jan 29, 2019 | 06:19 AM
rednrollin's Avatar
I have read that I will need to have the transmission error codes removed and the computer reset. This correct
Old Jan 29, 2019 | 07:30 AM
Yes, any TCM error codes will need to be reset.
This can be accomplished with any number of inexpensive code readers.
I have this one and know it works :
https://www.amazon.com/LAUNCH-CReader-Transmission-Diagnostic-Scanner/dp/B071K5GMHJ/ref=sr_1_20?ie=UTF8&qid=1548764742&sr=8-20&keywords=tcm+code+reader https://www.amazon.com/LAUNCH-CReader-Transmission-Diagnostic-Scanner/dp/B071K5GMHJ/ref=sr_1_20?ie=UTF8&qid=1548764742&sr=8-20&keywords=tcm+code+reader
but there are quite a few cheaper ones.
Bottom line, don't pay a dealer to do it.
sorr10
May 9, 2009 12:03 PM
Infinity
Oct 22, 2008 01:18 PM
jwheeler
Dec 9, 2005 10:39 PM
ejc45carter
Apr 1, 2005 10:11 PM
