no start after t/s battery drain by removing fuses
Old Jul 22, 2022 | 05:45 PM
white05conv's Avatar
Angry no start after t/s battery drain by removing fuses
I was trying to isolate which system is draining my battery by removing each fuse 1 at a time and watching amp draw
after checking fuses car wont start cranks but no start. is there something I have to reset
Old Jul 22, 2022 | 05:57 PM
Default Re: no start after t/s battery drain by removing fuses
Are you sure you got all of the fuses back properly? Also, hopefully you didn't cause an electrical spike. Usually, the battery draining is caused by the old internal batteries in the alarm siren leaking and shorting out.
Old Jul 22, 2022 | 07:12 PM
I will recheck all of the fuse and then check the screem
Old Jul 23, 2022 | 09:52 AM
If you disconnect the battery, reconnect it and get two almost starts and then nothing, it is probably the screem. Josh Chase at MSS checks and repairs them.
CaptainTommy
Oct 11, 2025 12:31 AM
paulius
Sep 26, 2019 09:53 PM
shyloe
68
Dec 9, 2017 11:54 AM
KROSSFIRE1988
38
May 4, 2010 04:54 PM
mcd0minguez
Nov 22, 2009 08:56 PM
