Replacing ABS module
Old May 31, 2023 | 09:10 AM
bhlavenka's Avatar
Default Replacing ABS module
How hard is it to replace ABS module and do they have videos on it?
Old May 31, 2023 | 10:10 AM
Default Re: Replacing ABS module
I've been a member here since 2009, I do not remember anyone replacing the ABS module or unit/pump.
I cant help but ask why you think yours is bad. If some shop is telling you that its bad, I'd consider a different shop. They are not known to fail.
Instrument panel ABS warning lights are (if that is what makes you/them think it is bad) are usually caused by the steering angle sensor, a goofy wheel speed sensor or bad relay in the RCM or fractured solder on the RCM.
bhlavenka
Jun 4, 2023 07:14 PM
glover
U.K.
Sep 24, 2022 09:41 AM
gragonese
Jul 5, 2017 04:50 PM
Steenport567
Nov 13, 2008 05:48 AM
