Grille Ribs??? Just need some confirmation....
Old May 23, 2024 | 09:08 AM
jasonk931's Avatar
Default Grille Ribs??? Just need some confirmation....
Hey guys,
I have an 06 coupe. On the stock Grille, I am wanting to paint the dark portion jet black, and keep the ribs silver. My question? Can you remove the individual silver ribs (pop-in) or are they glued into place? I away from my Coupe and was wondering if someone has checked this so I don't go and destroy the ribs. lol. Cheers!
Old May 24, 2024 | 11:18 AM
DTMenace's Avatar
Default Re: Grille Ribs??? Just need some confirmation....
Originally Posted by jasonk931
Hey guys,
jasonk931
The silver "ribs" have several tabs that are glued into the main grille, as seen from the back of the grille. There are 4 screws on the top of the grille to begin the removal, tilt forward slightly and the grille will be easily removed, so the bottom tabs will not be broken.
Once removed look at the back of the grille, you'll see the attaching tabs/slots for the ribs. DO NOT pry the ribs away from the grille at this time, since they (ribs) are fragile. Using a heated soldering iron, apply it against those visible rib tabs to loosen them up enough to help pry the ribs off the grille for your painting project. BTW, those ribs are 3 different lengths, so when reapplying to the grille make sure they are in correct order.
Good
Luck,
Dennis
DTMenace
Old May 24, 2024 | 03:02 PM
Hey guys,
Just a thought, but couldn't you just tape them?
Old Jun 8, 2024 | 08:50 PM
Originally Posted by DTMenace
jasonk931
Good
Luck,
Dennis
DTMenace
The silver ribs have rectangular tabs on them that fit into rectangular holes in the black part of the grille. the tabs are slightly longer than the depth of the grille holes. the rib tabs are heated and squashed thus riveting the ribs and grille together.
I think applying heat to the joint may in fact weld the two parts together.
more than they could be right now.
Painting and the use of silver tape over the silver ribs has been done successfully in the past.
Old Jun 10, 2024 | 05:13 PM
DTMenace's Avatar
Where's the OP, silence since May 23rd, with no response to the numerous replies in an attempt to help?
Seems like quite a few members never return to carry on the conversations, very odd....
Dennis
DTMenace
Semaj_1
Aug 20, 2019 06:57 PM
coryforman
Apr 13, 2017 06:15 PM
hopscotch
Nov 2, 2014 11:33 PM
colasr
Aug 27, 2013 12:52 PM
larrsz
Jul 14, 2012 03:52 PM
