Convertible top stuck half open
Old Feb 26, 2014 | 01:54 PM
wootto's Avatar
Angry Convertible top stuck half open
While cleaning the inside of the soft top on my crossfire I left the top in the vertical position to aid access. I removed the key to suspend the opening operation. Now the top is stuck in the vertical position. The switch to open/close the top is flashing but I cannot open or close the roof. Has anyone experienced the same problem if so what is the solution.
Old Feb 26, 2014 | 03:12 PM
Default Re: Convertible top stuck half open
I had that happen to me once too. If you leave it in a partial position too long ( @ 20 minutes or so ) the pump will drop all pressure.
What I did was to manually finish the top open process by placing the top in the well, then closing and locking the tonneau cover.
When I then switched the ignition on again, the button was no longer flashing, and the top worked normally.
Hope this helps.
Old Feb 26, 2014 | 05:52 PM
wootto's Avatar
Thumbs up Re: Convertible top stuck half open
Thanks for your reply from across the pond. I will take your advice tomorrow hopefully all will be well.
Old Feb 26, 2014 | 06:18 PM
Yea, the top's electric system is not designed for doing what you are doing.
If you want to play around with the top in an "in-between" position like that, do it manually.
Maybe this helps:
https://www.crossfireforum.org/forum...operation.html
Old Feb 26, 2014 | 06:42 PM
Here we have the classic question, is it stuck half open or half closed? Hmm.
Follow the advice above from the two pros and you'll be OK.
Old Feb 26, 2014 | 06:50 PM
and the thread title is "Convertible top stuck half open"
Old Feb 26, 2014 | 07:10 PM
He sat there with half a glass of beer. Half full or half empty?
Old Feb 28, 2014 | 02:31 PM
UK-SRT6's Avatar
How did you get on?
ZERACER
Jul 7, 2020 10:21 PM
Hoppy
Dec 7, 2018 07:36 AM
PimpDaddy
Sep 29, 2016 11:55 PM
Ralph289
Jul 26, 2015 12:52 PM
mike28117
Jul 17, 2015 01:59 PM
