**WEBSITE** Functions / Questions/ Suggestions Etc **NOT CAR RELATED** THREADS / DISCUSSIONS Post suggestions or questions regarding the FORUM FUNCTIONALITY etc. The Moderators will monitor postings here
Trying to modify my threads (3) on Double Din install
Old Dec 4, 2019 | 12:02 PM
Default Trying to modify my threads (3) on Double Din install
I want to modify my thread CLICK and all I see are the photos when I select EDIT.
The words got jumbled up last time I tried to edit, and now there are no words.
I can no longer control where the words will appear when I try and modify my thread 'Index .... ' in my signature.
I guess I might as well give up and abandon them or delete them.
I never get notification when someone has posted on a thread I have started or replied to, I have that option ticked.
Old Dec 7, 2019 | 06:02 PM
DTMenace's Avatar
Default Re: Trying to modify my threads (3) on Double Din install
I'm having issues with updating the SRT6 VIN# database as well. ALL of the verbiage is missing when attempting to update the paragraphs as related to the date, latest number in the database as well. This thread can not be updated, awaiting for a correction by the Moderators ASAP.
Regards,
Dennis
DTMenace
Old Dec 7, 2019 | 06:13 PM
Regards,
Dennis
DTMenace
I do not think they care much. I gave up adding or modifying my thread called ‘Index ......’
I have done the same to my Double Din thread.p
Old Dec 8, 2019 | 09:13 AM
DTMenace's Avatar
180
I guess the database updates will be on hiatus until this problem is resolved.....
BTW, the color selection has been reduced as well on responses.
Dennis
DTMenace
Old Jan 17, 2020 | 02:31 PM
Robb M.'s Avatar
hi everyone,
Sincere apologize for having missed this thread. Thanks to @Valk for sending us an email.
@onehundred80 if you edit your thread, go to advanced mode and then click on 'source' to the top right of the text window, are you able to see your text?
Similarly for @DTMenace does the above work for you?
cheers,
robb
Old Jan 17, 2020 | 04:37 PM
Originally Posted by Robb M.
hi everyone,
cheers,
robb
This problem only applies to long posts, short posts are OK. On long posts I can only see the attachments which are in the normal layout.
When I hit ‘source’ in long posts I only see what I take to be code inter spaced with my original text and I cannot figure out what it actually what the code says.
Last edited by onehundred80; Jan 17, 2020 at 04:44 PM. Reason: Added the inter spaced word.
Old Jan 17, 2020 | 10:41 PM
IB JT's Avatar
IB Staff
@onehundred80 this issue appears to be related to your signature issue. It's due to the size tag usage as it's not fully supported. I also see a similar issue where the HTML tags are stacked, such as the case with your signature, but the real issue is the size tags aren't fully supported and they're breaking the What You See Is What You Get Editor.
Like I said in your Signature thread, I'll check with the team on Monday to see what the thoughts are about the size tag issue.
Thanks.
DTMenace
May 7, 2026 05:23 PM
onehundred80
23
Apr 24, 2019 07:30 PM
green-ghost
Sep 26, 2009 10:04 AM
XFiringInNC
Jun 28, 2009 11:51 AM
Miata 5.0
Aug 28, 2007 10:26 PM
