AMG or SRT6 Sway bars??
Re: AMG or SRT6 Sway bars??
Originally Posted by dynamicS
Just curious if anyone here has the AMG sway bars on your XF? How does it steer, more or less under steering?
I'm thinking of scrounging up a rear sway bar from the SRT6, I can imagine it's cheaper than AMG stuff.
I listed the specs of the different bars in some thread on this forum... I would highly recommend the swap... Limits body roll by about 3 degrees. As far as understeer / oversteer, I couldn't tell you for the stock set-up since I run a -2 degree camber adjustment from the OEM and run a .75 toe out...
The limited/base model Crossfire in the front has a 25mm sway bar, where as the SRT/AMG is a 27mm sway bar... and the H&R sway bar is 30mm.
Here's the link for Tire Rack:
http://www.tirerack.com/suspension/s...769&perfCode=S
I would like to get more oversteer. So I'm guessing I should stiffen up the front sway bar correct, or do I have that as*backwards?
rogerlemoine
10-26-2015 12:02 AM
2005 Ragtop
10-03-2015 03:01 PM
