Chunk out of a brake shoe
Old 07-28-2007, 01:54 PM
bflinn's Avatar
Default Chunk out of a brake shoe
I just replaced my stock pads with EBC Red Stuff ceramics and when I removed the stock shoes the left, front outboard pad was missing a chunk - see pic below. I assume an anomaly but thought I would pass it on...mine is a "new" 2005 SRT-6 with 800 miles on it.
Old 07-28-2007, 02:28 PM
crossfirefun's Avatar
Default Re: Chunk out of a brake shoe
Looks like a rust, delamination problem. I will have to check mine too as it is a leftover '05.
Old 07-28-2007, 03:04 PM
UK ken's Avatar
Hi
I am always reading about the "Red Stuff" brake pads... Is there any increase breaking improvement over the standard fitted pads?
Ken
Old 07-28-2007, 03:21 PM
HDDP's Avatar
If your car only has 800 miles on it and those pads are as rusted as that, I would take the car back to the seller and demand a complete inspection... That looks like the car sat in some serious deep water... Look at the attachment plates... I know that those are at least 1 ft. above ground level...
Old 07-28-2007, 03:28 PM
HDDP's Avatar
CAN YOU SPELL FLOOD DAMAGE FROM A DEALERSHIP IN LOUISIANA OR MISSISSIPPI DURING KATRINA ?? >
CARFAX that thing.
Old 07-28-2007, 04:20 PM
bflinn's Avatar
I have carfaxed it and it came from a dealership in PA...i was under the whole car, its not a flood car. All cars braking systems rust, especially when not driven. This SRT was built in Sep 2004 so it is 2 months shy of 3 years old. Take any car for 3 years, don't drive it and see what the rotors and cheaply painted brake shoe hardware does...it will rust, as rust will find every possible nick and spread. Car is fine, brakes are fine etc. Maybe its a 1 in a 1000 bad shoe, maybe the car was washed in 2004 in place and never driven and water was in the shoe...maybe...Thanks for the concern.
BTW on the Red Stuff...seem great so far, very short test drive, I'll post an update "down the road".
Old 07-28-2007, 04:46 PM
woody's Avatar
Please keep us informed on the Red Stuff front. I have not been impressed with the Green Stuff, at least not with the stock discs. I found them little better than the stock setup on the track in terms of fade and pedal feel, and less reassuring on the road in day to day driving due to needing a few applications to get some heat into them to get the same initial bite. It could just be me though as I am not usually that aggressive with the brakes on the road.
Old 07-28-2007, 06:02 PM
HDDP's Avatar
Woody, Never got an answer to my last PM... Figured you were busy... Re-learn and your carsoft to see if the fuel / timing will re-adjust... ???
PS: just looking at the 1/1, 1/2, 2/1, 2/2 02 sensors and the wiring schematics from the manual... On the sensors there are 2-wht, 1-gry, 1-blk... This does not correlate with the connector diagram in the manual (not surprising) I'm looking to tap the signal back to the ECU on the sensor itself, instead of after the connector... I'm going to try a adjustable voltage clamp to see what it does...
Old 07-28-2007, 06:37 PM
woody's Avatar
Hi Derek, sorry for not replying, had to work this morning then spent the afternoon laying about under the car sorting stuff for the track next week. Just started to check the forum now. I'm going to spend some time on the wiring tomorrow re. esp/tc and ECU, so I'll check out the o2's too. I'll PM you a bit later with some info. Simon. */end threadjack
Old 07-28-2007, 07:02 PM
HDDP's Avatar
Got it sorted already... FYI the sensors downstream of the connector do not have the same wire color as those upstream of the connector...
Have fun with your project... I'm in a similar process this weekend since the wife is out of town...
Have you ever heard of dampening the knock sensors ?... That's in the works as well... The process requires adding a spacer / damper to the attachment points ...
Removed the AC pump and ran a new drive belt and it clears the other pulleys without a problem... So, I just got rid of 6.8 kilos of useless weight without having to install a dead pulley...
Cheers... Gotta get back to the garage...
syfi
12-11-2023 07:31 PM
Valk
01-16-2023 10:49 AM
RamblinShamblin
08-12-2017 10:55 PM
8ighth Wonder
12-15-2015 01:42 PM
ritous1
09-26-2015 01:27 PM
Quick Reply: Chunk out of a brake shoe
