camber kit questions
Old Oct 16, 2008 | 12:38 PM
srt-6novice's Avatar
Default camber kit questions
when you change out the springs and struts should you insatll a camber kit when running 19 on the ack and 18 on the front.
Old Oct 16, 2008 | 06:38 PM
Fritzauf's Avatar
Default Re: camber kit questions
It depends on how low you go. I installed the Eibach Pro kit and Koni adjustable dampers (best mod for the $$$). There is a very slight neg rear camber but the tire wear is even across both tires. I have not had any problems and have no need for the camber kit yet. but... You really won't know until you try.
Old Oct 17, 2008 | 03:55 AM
andrew's Avatar
-C-I-C-C-I Associate Member
~ ditto...
Old Oct 29, 2008 | 05:23 AM
cmac's Avatar
how far was your rear camber out ? Mine after installing the same combo was at -2 in when its supposed to be -1 1/8 with a 1/2 in tolerance each way.
Old Oct 29, 2008 | 10:51 AM
im unsure, but just wondering if i will need a camber kit
Old Oct 30, 2008 | 02:54 AM
Steve Hellums's Avatar
I done the camber kits on front & back when I installed the Eibach Pro kit. Here is the post I started back when I done it. Post #39 is the most discriptive of how things turned out. Hope it helps, I'm the only one that done the camber kits that I know of. https://www.crossfireforum.org/forum...ad.php?t=16136
Old Oct 30, 2008 | 07:53 AM
just read the thread (all of it) after all is said and done, are you happy with your decisions. give me a follow up on the after thoughts. thanks for the help
Old Oct 30, 2008 | 11:48 AM
Over all I'm happy with it. But with the wider wheels and tires I do get a little rub straight up in the fender wells on front, but that has nothing to do with the camber kit. I do believe the springs settled a little on front & back, witch the tech at Eibach said they would not. The reason I had called the tech was because the back of the car did not lower but about a 1/2". I made a set of 1/4" spacer to insert above the front spring cups to help with the light rub when I would hit a big dip in the road and it worked fine at first, but the rub is back thats why I think the springs settled, plus I can tell the back tire's are a little closer to the fender now. I need to check into getting thicker set of spring cups for the front.
Old Oct 30, 2008 | 08:10 PM
what was the name of the part you purchased for the front camber from the dealer. also what is the size of your wheels and tires.
Old Oct 31, 2008 | 02:38 AM
The front bolts was called an eccentric camber bolt kit for $14 a side. The front wheels are 18"X8.5 with 245/35/18's tire's and the rear wheels are 19"X9.5 with 285/35/19's, both front & rear wheels were a 35mm offset. I also have 10mm hub centric spacers on front and 20mm's on the rear.
Old Nov 4, 2008 | 07:00 PM
what is the part # for the eccentric camber bolts. i went to the dealership today and told them the name of the part, but it cost me $31.00 each side. was just wondering if i got ripped off or if i ordered the wrong part
Old Nov 6, 2008 | 03:53 AM
I'm at work right now, I done some searching on the net, but couldn't come up with anything. I probably have the bags the bolts came in at home with the OEM bolts in them if you really need the #'s, I've kept all the OEM parts for my car in boxes up stairs in my garage. Did you get 2 or 4 bolts from your dealership? It only requires 1 for each side, the kit included the bolt and 2 washers that have shoulders on them offset to one side.
UNDER PSI
Nov 1, 2015 09:39 PM
Idrenak
Sep 19, 2015 08:17 PM
ayebb
Sep 18, 2015 03:35 PM
Valk
Sep 17, 2015 11:43 AM
Big Daddy
Sep 10, 2015 10:21 PM
