rear bottoming out??
~ on the factory rear shocks there is a rubber bump stop (located on the shock piston/shaft)... when adding lowering springs these need to be trimmed down... this will eliminate the feeling your experiencing. you will have to remove the rear shocks in order to complete the trimming. a simple task with a few hand tools.
Originally Posted by acrispy1
Do as Andrew says, I did what he said when I lowered my car, no problems.
Originally Posted by Mad_Med05X
Are the stoppers only on the rear?
How do they look before and after you trim them?
https://www.crossfireforum.org/forum...3&postcount=17
2005 Ragtop
Oct 3, 2015 03:01 PM
