Help!!! How To Change Wheel Bearings
Old May 14, 2009 | 11:40 AM
murtazanooruddin's Avatar
Default Help!!! How To Change Wheel Bearings
my xfire makes a rubbing noise while im driving at slow speeds a buddy of mine told me its prlly wheel bearings any advice? any help would be greatly appreciated
Old May 31, 2009 | 10:41 PM
DMS Xfire's Avatar
Default Re: Help!!! How To Change Wheel Bearings
I thought the same on ours and the noise went away when I bought new tires. Have your tires checked if they OEM Conti's exspecially.
Old Jun 4, 2009 | 02:35 AM
Style's Avatar
If it was wheel bearings it would be more of a grinding noise. How many miles has your xf done?
Old Jun 4, 2009 | 09:46 PM
Bladecutter's Avatar
Did you lower your car, or install different tires than the stock sizes?
If so, you might want to check the tires and see if they are rubbing against something in the wheel wells first.
BC.
Old Jun 12, 2009 | 08:05 PM
nhmercracer's Avatar
I would also check the rear brakes. With time, the pad guides on the single pin rear calipers can wear down. This will allow the pad to rotate in the caliper and make some really strange noises.
PNA
Nov 12, 2020 04:44 PM
Roty135
17
Oct 11, 2018 10:11 AM
cdcrone123
27
Sep 24, 2015 11:28 AM
cdcrone123
Aug 4, 2015 06:37 PM
Jul 29, 2015 06:13 PM
