If you are installing eibachs on your srt...
Old May 25, 2009 | 12:01 AM
bhays's Avatar
Default If you are installing eibachs on your srt...
If you are installing eibachs on your SRT and it's the first time you have done such a job, a few notes..
1. Don't be alarmed that the Eibach springs are longer than the factory springs, they will sit lower.
2. Be sure to rotate the rear springs so that the end of the spring sits down into the little pocket in the lower A-Arm before you reassemble... (ask me how I know).
For a few minutes this afternoon I had the first off-road SRT6... oh well, if a job is worth doing it's worth doing twice
Also, don't assume that your rims from your base roadster will fit your SRT... calipers hit in the front due to being much larger than the base calipers... already ordered 5mm spacers and longer lug bolts from ezaccessory.com... Ticks me off as I ordered 15mm spacers and lugs for the rear and didn't even consider the fronts since they fit fine on the other Crossfire...
Old May 26, 2009 | 10:27 PM
BlUEMDsrt6's Avatar
Default Re: If you are installing eibachs on your srt...
Cool, I just got my H&R springs and Spacers(5mm front & 15mm rear) and I can't wait to have them installed. What size spring pads did you use? Also what size lugbolts?
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ozkancab
Sep 25, 2015 10:55 AM
