DOT 4 Plus...
Old Sep 21, 2009 | 02:18 PM
smfrycruzr's Avatar
Default DOT 4 Plus...
While doing my oil change this morning I noticed my brake level was a little low in the resevoir. After going to AutoZone and NOT finding a DOT 4+, with the correct boiling point, I had to go all the way to downtown OKC to the ONLY M-B dealer in town to buy a 1 L bottle @ $25.47 just to top off my brakes!
Is there somewhere else to get our "SPECIAL" DOT 4+ brake fluid other than at the "stealerships"?
Sorry about the rant, just hate driving in OKC. Thanks for any heads up.
Old Sep 21, 2009 | 03:34 PM
maxcichon's Avatar
Default Re: DOT 4 Plus...
If you had to add fluid, have you checked the pad thickness for the brakes? They might be getting thin and this would explain where the fluid went...
Old Sep 21, 2009 | 04:34 PM
tighed1's Avatar
Dry boiling point
Wet boiling point
DOT 3
205°C (401°F)
140°C (284°F)
DOT 4
230°C (446°F)
155°C (311°F)
DOT 5
260°C (500°F)
180°C (356°F)
DOT 5.1
270°C (518°F)
191°C ( 376°F)
DOT 4 only goes to 446°
Manual sez:
Use brake fluid approved to MB331.0, or a DOT 4 brake fluid with: minimum dry boiling point (ERBP) 500°F
That's strange!
Old Sep 21, 2009 | 07:10 PM
smfrycruzr's Avatar
After running all over town to find this jewel of on oil, I didn't need it after all! My old eyes played a trick on me, poured some fluid in and promptly over filled the resavoir. If I had only shaken the thing first I would have seen where the fluid actually was, DOHH!
Live and learn.
P.S.- had to suck out the extra fluid, NOT FUN!
Old Sep 22, 2009 | 09:03 AM
former NXMX5's Avatar
be careful... dont just throw DOT5 in there because of the boiling points... DOT5 is silicone, whereas DOT3/4 is glycol. Our systems wont work with DOT5.
Old Sep 22, 2009 | 09:26 AM
AllEuro's Avatar
You should just use Motul RBF600. Check it out here: Discount Motul 600 Brake Fluid - RaceShopper.com
I use this stuff to track my corrado and I also buy it from these guys. I've never had a problem. I used to use ATE Superblue, but I heard bad things about the blue dye and the various seals inside the brake system. So now it's exclusively Motul. I'll probably use this stuff when I change out the fluid in the crossfire. Though I think it's a bit overkill on a car only driven on the street--or even autocross.
Old Sep 22, 2009 | 09:57 AM
tighed1's Avatar
Was going to ask, "Why won't they work with Dot 5?" So those that are also wondering I did a Wiki search and found this,
Using DOT 5 in a DOT 3 or DOT 4 system without proper flushing will cause damage to the seals and cause brake failure. DOT 5 brake fluid is not compatible with anti-lock brake systems.
News to me.
Old Sep 22, 2009 | 01:17 PM
32krazy!'s Avatar
if you try your local metric motorcycle shop they should carry motul blue brake fluid with adry bp of 530*
2005 Ragtop
Oct 3, 2015 03:01 PM
Mikerdougie
Aug 2, 2015 02:04 PM
Hindin
Aug 18, 2011 06:03 PM
Germany
Sep 10, 2010 07:14 PM
Maxwell
Jun 30, 2008 02:07 PM
